Your thoughts CACO? - Car Audio Classifieds!
Old 04-11-2015, 01:01 PM
0/11 ssssss128
Question Your thoughts CACO?
Ordered a X10 v2 d2 and a SCV-2000D a couple of days ago.
Hopefully i can just put it in the box i built for the v1 but never installed.
Designed the box with torres to fit in my Ranger and built an enclosure with 1" mdf that is 14h x 17d x 24w with a 2" wide port (33.5" physical length) and with the displacement of the v1 it was smack dab right on the spec's listed on the SD website (1.5 cubes net, 24" port area & tuned to 32 hz.
For power i have a mechman 170A charging a group 65 NSB under the hood and will be adding another one in the box. The big 3 is done with ce auto elect. supply 2 ga. tinned OFC with a run of the same back to the box of the truck.
I'm only making 170amps under the hood and will have a battery within 4-5 feet of the amplifier i'm wondering if i have done a sufficient job or if i should consider more electrical upgrades?
Old 04-11-2015, 02:26 PM
So Low's Avatar
0/11 sssss1258
Overkill is underrated
Old 04-11-2015, 02:44 PM
andy75's Avatar
0/11 ssssss788
Should be fine once you have the rear battery.
The Following User Says Thank You to andy75 For This Useful Post:
Markous (04-12-2015)
Old 04-11-2015, 02:50 PM
0/11 sssss2091
Well said!
Old 04-11-2015, 03:03 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
Youll be fine. Ive had more power on less electrical.
The Following User Says Thank You to oslouie For This Useful Post:
Old 04-12-2015, 06:52 PM
0/11 ssssss128
Thank you for the input so far.
Old 10-08-2016, 05:30 AM
0/11 ssssss128
Default Necro bump with a question
So i'm running a Zv4 10" in the same box and the SCV-2000D i had planned for the X-10 and it sounds great.
Only thing i've changed since the OP was i stepped up to a 250A mechman and replace the 2ga. with 2/0 welding cable.
This is what it looked like in Torres,
I was wondering if someone here could post a screenshot of what the output response curve looks like with win isd, term pro or some other modeling software of the like.
I've tried win isd and had no luck, kept getting an error message as i must have input some of the T/S spec's incorrectly and pretty much rage quit on trying again.
Also curious of what the projected port velocity would be and if it's too low or to high.
'07 Ranger Sport|Ext.Cab|3.slow|Mechman Elite 250|NSB Group 65(x3)
iPhone 6+ side slider|HRT iStreamer|AudioControl Matrix+ & EQS
Sundown Audio SA-6.5CX|SAX-100.4|SCV-2000D|Stereo Integrity HST-15 MKII
thoughts?? newarkbeast973 Off Topic Chat 0 03-11-2012 08:05 PM
Show off your CACO or Team CACO decal contest Patrick Simmons CACO Contests 138 06-19-2011 10:24 PM
Thoughts...? Scapelli21 (Sundown Audio) 16 02-05-2011 04:54 PM
