box design question - Car Audio Classifieds!
Old 04-19-2015, 09:22 AM
0/11 ssssss308
Default box design question
Im helping a friend with his install, he wants to go four 15's in a sierra. basically have the same truck as mine so the measurements are 55w 32h and 27d do you guys think its enough room to go with four small box 15 without going with a wall...i said yea buy im no box designer
Old 04-19-2015, 06:28 PM
0/11 sssssss65
It would be do able. Those dimensions give you about 24 cubes befor displacement. It might help to know what 15s, what amps,electrical etc.
0/11 sssssss65
It would be close though
Old 04-19-2015, 06:30 PM
I would go 3 15's port and subs up if it was my truck.
Old 04-19-2015, 06:33 PM
0/11 sssssss65
I'm running one 18 in a f150 in only 7cubes and box is huge. Might consider a wall if its a option to fit four the best.
Old 04-19-2015, 06:40 PM
0/11 ssssss308
I know he's going with small box 15's but not sure if he's going with the ethos or dc I'll have to check with him
Old 04-19-2015, 06:44 PM
0/11 sssssss65
Like korey said if a walls not a option I would do three 15s sub/port up or two 18s. also would try aeroports to help save space.
Old 04-19-2015, 06:50 PM
0/11 ssssss308
It will be about 12 inches from the roof
Old 04-19-2015, 07:05 PM
0/11 sssssss65
If you/he did three you could fit them firing forward. But you original question 4 would have about 6cubes each to play with after port and sub displacement I would assume between 4-5 cubes per sub so it should be pretty close. If you did four at 32 high you might be able to fit them two high forward firing but it would be really close. If you could do 55x34x27 you should be able to get away with it. Not sure if that helps at all.
Old 04-19-2015, 07:16 PM
0/11 ssssss308
I think the ethos and dc (whichever route he go) need about 3 cubes per
question about the port of my box design markak134 Enclosure Discussion & Design Construction Help 4 01-03-2013 04:03 PM
Box Design question and help? hypnoticbeatz Enclosure Discussion & Design Construction Help 1 02-27-2012 01:52 AM
box question (NOT A DESIGN QUESTION) highpsicobra General Car Audio Discussion & Questions 0 07-15-2010 02:10 AM
Box Design Question worstenemy453 Enclosure Discussion & Design Construction Help 18 10-23-2009 03:11 PM
quick box design question jmkanek General Car Audio Discussion & Questions 0 06-21-2009 09:23 PM
