box for blow thru. - Car Audio Classifieds!
Old 09-22-2009, 08:14 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
Default box for blow thru.
so im gonna blow thru my truck. found a tonneau cover for it. so ill do it this way. im wanting to put the port in the center of the subs. but i cant seem to get the tuning right. i need 38-40hz tuning.
atomic told me 4.0 cf per sub with 20 sq inches of port 8 inches long. to this must be aeros. but what size? if i do slot its hard to get the tuning anywhere close.
i can do 14 inches high, 40 inches wide, by as much deep as i have to. subs are atomic ap/spl that are going to be a spl comp / daily setup. each sub displaces .15 cf.
this way if i do 40 side i can fit amps behind the seat, bats next to the box in the empty spaces or behind it or whatever. amps going to be a 3250v2. subs get here monday
Old 09-23-2009, 08:07 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
nobody? box pro has been pissing me off for 2 days. cannot get the ports right.
Old 09-23-2009, 08:14 PM
0/11 ssssss714
This is my blowthrough box I designed. 15'' tall x 40'' wide x 28'' deep. The baffles are recessed 5'' and the port is 5'' wide x 13.5'' tall. It comes out to [email protected] I think. Just mess with the dimensions and get very familiar with google sketchup and you can design your own based off this one.
Old 09-23-2009, 08:16 PM
bassman_soundking's Avatar
0/11 sssss2063
common chamber one port?
8 ft3 total?
I need a H/O alt for my 2006.5 Scion xB
Sold to: Jonesy
Traded with: Jonesy, 310w6, Ciaonzo
Bought from: newtitan. T3audioNavi
Old 09-23-2009, 08:27 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
yea i need at least 4 cubes per sub. would like one port in the center with the baffle flush on the back cab wall
Old 09-23-2009, 08:34 PM
0/11 sssss2063
so 12" subs then?
Sold to: Jonesy
Old 09-23-2009, 08:39 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
yea. atomic ap/spl 12's. daily SPL setup
Old 09-23-2009, 08:41 PM
0/11 sssss2063
I can model some different stuff. you want only 20 square inches of port tho for an 8 + ft^3 box?
Let me know I have bassbox open right now. here is one possibility
40 wide 14 tall 30 deep 12.5x8 port 12long tunes to 38 hz 8.7 net in box. I would recommend more port area still than that though. But you said 20^2 port and that is already 5x that.
switch port to 12.5x10 19 long tunes to 38 with 8.04 ft^3 net
Sold to: Jonesy
Old 09-23-2009, 08:44 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
atomic told me this in an email. so its very broad comment.
daily / comp for APSPL12 is 4.0 cubic ft with 20 square inch port by 8 inch depth
displacement for the sub is 0.15 cf.
Old 09-23-2009, 08:45 PM
0/11 sssss2063
the general rule is 12-16^2 port area per ft^3 box volume
Sold to: Jonesy
my old blow-through thumper21 Car Audio Videos 6 05-19-2009 01:53 PM
gasket for blow through MC AUDIO Wanting to Buy (WTB) 5 02-12-2009 09:28 PM
Blow-throughs... RE_Gawker Enclosure Discussion & Design Construction Help 31 11-02-2008 05:25 PM
Avalanche blow thru bones22 Build Logs 38 10-01-2008 11:09 AM
