cut mounting hole? - Car Audio Classifieds!
Old 04-22-2015, 09:45 PM
bassman_soundking's Avatar
0/11 sssss2063
Default cut mounting hole?
I am wondering what tool people use to cut out a double layer (1.5") baffle
Router...jigsaw...?
I have a router, but no jig. Also my router isnt the plunge type.
I have a jigsaw too, but last time I cut a thick baffle it didnt cut the hole properly
I need a H/O alt for my 2006.5 Scion xB
Sold to: Jonesy
Traded with: Jonesy, 310w6, Ciaonzo
Bought from: newtitan. T3audioNavi
Old 04-22-2015, 10:30 PM
0/11 ssssssss8
I use a jigsaw. slow and steady.
Old 04-22-2015, 10:34 PM
jmfrb1's Avatar
0/11 ssssss125
I've used a fixed base router, but with a jig. It leaves a small little indent that a plunge wouldn't but nothing too bad or noticeable once a sub is mounted
Old 04-22-2015, 10:51 PM
0/11 sssss2063
I did that last time and the hole was slightly bowed inward toward the bottom of the bottom board.
My jigsaw is old, and maybe I just need a better one.
Where do you find a bit long enough to cut 1.5" deep though?
Sold to: Jonesy
Old 04-22-2015, 11:03 PM
0/11 ssssss245
Get a piece of 1/4 plexiglass or lexan or plywood and make a circle jig for your router. Take the bottom plate off of your router(the plastic piece) and trace it out on the material and mark the screw holes. This jig will replace the bottom plate. Use a 1/4 router bit and measure out the length of the radius of the hole you need from the outer edge of the bit to where you will put a screw to pivot.
bassman_soundking P.S. I didn't forget about that alternator I think I know what alt you can get for cheap its a hairpin 220amp. But even if it will bolt on not sure if it will clear everything on your car.
The Following User Says Thank You to expo615 For This Useful Post:
@udioholic (04-30-2015)
Old 04-22-2015, 11:10 PM
I use a jigsaw. Cut one baffle at a time instead of trying to cut through so much material.
Old 04-22-2015, 11:13 PM
jmfrb1's Avatar
0/11 ssssss125
I cut the baffles individually. I made my initial center hole with them clamped together so they were centered spot on with each other
Old 04-22-2015, 11:18 PM
0/11 sssss2063
I have thouight about that, and there is a plastic store by me (TAP Plastics)
Box is already assembled so I cant do one at a time.
I wasnt thinking ahead.
Sold to: Jonesy
Old 04-22-2015, 11:19 PM
Hdorre's Avatar
0/11 ssssss540
i used my router. Heres the bit i used on my double baffle.
Old 04-22-2015, 11:29 PM
0/11 sssss2063
I am looking this up right now
EDIT
Looks like the cutting edge is 1"
So make a 2nd pass with the bit lowered or something to cut through the remaining 1/2"?
Sold to: Jonesy
hole cut outs for DC lvl4 m2 12's Black Toyoda Enclosure Discussion & Design Construction Help 2 10-30-2013 10:54 AM
inverted mounting hole badfish Enclosure Discussion & Design Construction Help 3 03-16-2011 02:24 PM
mounting hole size glass22 General Car Audio Discussion & Questions 0 06-03-2010 11:14 PM
Cutting speaker mounting hole KcRidin09 Enclosure Discussion & Design Construction Help 6 03-22-2010 02:48 PM
Mounting hole for a 15" nightshade? AbsoluteAudio (Sundown Audio) 2 12-15-2009 04:12 PM
