wall build question - Car Audio Classifieds!
Old 04-25-2015, 03:45 PM
noknok's Avatar
0/11 sssss1521
Default wall build question
I am about to start my wall build. My problem is can I use my trunk also to get more box volume? Or would it be better to keep box square as possible in the back. I could use the space I have in the trunk to make my port longer for more port volume if it works. Here's a pik of my trunk wall that I am thinking of adding to my wall.
Old 04-25-2015, 10:43 PM
noknok's Avatar
0/11 sssss1521
Anyone
Old 04-25-2015, 10:53 PM
Lock up your daughters!
0/11 sssss1342
Yes, you can use your trunk to get a little extra volume. Just make sure the inside is nicely sealed
Old 04-25-2015, 11:35 PM
noknok's Avatar
0/11 sssss1521
Ok thanks..
Old 04-26-2015, 03:07 AM
You absolutely can. That trunk looks solid, so if the workmanship remains on par with that it should be killer.
Old 04-26-2015, 05:13 PM
noknok's Avatar
0/11 sssss1521
Thank you sir.. I'm going to start the build this week
Old 04-26-2015, 05:47 PM
So Low's Avatar
0/11 sssss1258
I've seen that done in smaller cars with flat wall 4th orders needing more sealed volume.
What's the build?
Hatchback guys: To wall or not to wall; that is the question Synestersnake31 General Car Audio Discussion & Questions 36 03-05-2014 02:09 AM
solid baffle wall build question lilsoccersully Enclosure Discussion & Design Construction Help 10 02-10-2014 12:31 PM
wall question nuboot General Car Audio Discussion & Questions 3 02-05-2013 09:55 AM
wall question massivespl General Car Audio Discussion & Questions 16 10-02-2011 10:39 PM
Wall question maverickdog8 Enclosure Discussion & Design Construction Help 12 06-11-2011 12:05 PM
