Front Loading Horn vs 4th order - Car Audio Classifieds!
Old 09-25-2009, 01:09 AM
MisterGrubbs's Avatar
0/11 sssss2358
Default Front Loading Horn vs 4th order
I would like for someone to please, in as many ways as possible, to explain to me the difference in a front loading horn(or rear, for that matter) vs a 4th order in their major design differences.
Also, roughly how much space, do you think(feasibly) it'd take to create a front loaded horn enclosure for a single 18" Driver.
Just an off-ball question that I was having a debate about. It's hard arguing with yourself, you know?
Ryan
Old 09-25-2009, 01:12 AM
0/11 sssss6075
Spam
Old 09-25-2009, 01:13 AM
well they are bothbandpass enclosures but the horn has more gain
Old 09-25-2009, 01:14 AM
xseveredveganx's Avatar
Chainsaw Squad
0/11 sssss3380
Originally Posted by terra View Post
Spam
I agree to both the above.
Old 09-25-2009, 01:15 AM
0/11 sssss2358
What are the major design differences though?
Old 09-25-2009, 01:17 AM
null_void's Avatar
0/11 sssss5915
the 4th order is basically "ported" out the front, whereas the horn is more of a "box inside of a box"; it uses the way the subs load from the front and forces it thru a smaller opening, and opens back up again. there aren't alot of front loading horns designed really
they have inn common that they are sealed behind the cone
Old 09-25-2009, 01:23 AM
Chainsaw Squad
0/11 sssss3380
Yes and no. A front loading folded horn is a sealed enclosure firing into a horn labyrinth.
A 4th order is a sealed enclosure firing into a seperate, ported, second enclosure.
Old 09-25-2009, 01:26 AM
null_void's Avatar
0/11 sssss5915
not necessarily. the front loading horn doesn't have to fire into a horn labryinth. all it has to be is squeezed thru a port smaller than the flare. well the only ones i've ever seen are set up like that. i'm sure they do fire into a traditional loaded horn style setup, but they don't have to
Old 09-25-2009, 01:27 AM
0/11 sssss2358
That's as simple as you can explain it, although not very technical.
Old 09-25-2009, 01:28 AM
null_void's Avatar
0/11 sssss5915
well there are simpler/more complex designs than that, obviously. he was kinda just summing it up
Anyone ever seen this horn design before? Bigboiii Enclosure Discussion & Design Construction Help 21 07-31-2009 02:53 AM
Horn Box null_void General Car Audio Discussion & Questions 45 02-18-2009 02:15 AM
Horn be gone!!! tater General Car Audio Discussion & Questions 6 01-18-2009 02:41 PM
rear-loading folded horn box build SPY Off Topic Chat 22 10-08-2008 09:21 PM
