4th Order Blow Through - Car Audio Classifieds!
Old 05-19-2015, 08:19 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
Default 4th Order Blow Through
Guys I'm looking for some opinions on a 4th order blow through. I will be using Incriminator Audio Lethal Injections. I have around 31 cubes net to work with. I was thinking about 4 15s or 6 12s.
What would be the best option, best ratio etc. This is a spl comp truck and will see some demos. The truck peaks anywhere from 26-31 at the headrest. Power is around 5k right now and will be 10k later.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 05-19-2015, 09:15 AM
0/11 ssssss463
take total available cubes divide by 3. that will give you a 2:1 ratio breakdown. now, find a combination of subs that is optimized for the available sealed volume available. its a starting point. fine tune from there.
31/3=10.3cubes in the sealed section 10 12's would work, 5 15's, 3 18's, etc...
Old 05-19-2015, 10:15 AM
1loudmonte's Avatar
0/11 sssss2167
Thanks, now the 31 net would be before sub and baffle displacement inside. I know did have a blowthrough, not sure if you still do. How well did it perform? Also where did you get your design from?
Old 05-19-2015, 11:02 AM
0/11 ssssss463
had several in my truck. never one as big as you are planning. all played very well. if you get too large of a ratio, you limit your bandwidth. i designed all of them. send me your max dimensions and i can sketch up something.
Old 05-19-2015, 12:01 PM
1loudmonte's Avatar
0/11 sssss2167
Pm sent.
4th order blow thur projectred Enclosure Discussion & Design Construction Help 11 07-12-2012 05:39 AM
4th order blow through or wall? Re_Silverado Enclosure Discussion & Design Construction Help 14 12-05-2011 06:25 PM
99 Accord 4th order blow through BoominTempo Uninterrupted Build Logs 7 09-28-2011 11:41 AM
dbdragguy's 4th order blow-through Pioneer~Saturn Build Logs 143 09-17-2011 12:52 AM
99 Accord 4th order blow through BoominTempo Build Logs 0 11-21-2009 12:24 AM
