Need Amp Rack Help ASAP! - Car Audio Classifieds!
Old 09-29-2009, 10:11 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Default Need Amp Rack Help ASAP!
So I'm at a standstill, have tonight, part of tomorrow and about an hour saturday morning to get this install completed. I'm so boned.
The amp rack I started on wont work because I forgot about parts of it.
I need to mount my SAX 125.2, my SAZ-1000D and my batcap 800 in the Z between the strut bar and the little hump behind the seats.
I have 7" to work with on the base if I raise it up 1" off the floor to give room for the wires and a baby seat hold down to clear.
I am about to my brains end trying to figure out what to do here so all help is appreciated.
Team CACO Team SHOK
Supporting Member
Old 09-29-2009, 10:16 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I want it in the area that the box is sitting in in the 3rd pic.
I have 46" across the front, 7" on the bottom front to back, and I cant remember what the back is. I THINK it is 26.5" but I have to go out in the garage and look what I wrote down.
The amps need a panel 11" wide to mount horizontally.
Team CACO Team SHOK
Supporting Member
Old 09-29-2009, 10:20 PM
how tall?
Old 09-29-2009, 10:22 PM
oh and batt cap dimensions
Old 09-29-2009, 10:24 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Battery box inside
7.25 x 3
Outside
7.75 x 3.5”
That is what I have down for the batt box.
And I have to go measure the bar to see how high I can go.
Team CACO Team SHOK
Supporting Member
Old 09-29-2009, 10:26 PM
well if 14" works I got an idea
Old 09-29-2009, 10:28 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I can't do elaborate angles unless you can tell me what specific angle to set the saw at. I already tried it and couldn't get them to line up. Also I don't know how I'm going to secure it together. I don't have a nail gun and 1/2" is thinner than I thought so screws will split it.
I think fire + Z = win!
Also is the 14" at a 90" angle from the bottom of the hatch or is it at an angle back? It can be at 110* back towards the back of the car to follow the angle on the strut bar.
Team CACO Team SHOK
Supporting Member
Old 09-29-2009, 10:32 PM
it's a pretty easy thing to do you can probably clamp this as well
only 1 angle to cut give me like 5mins to finish and I will post up a picture
Old 09-29-2009, 10:35 PM
0/11 ssssss138
Looks good man, good luck
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Also it has to split into 3 pieces with the batt box separate.
And just FYI the batcrap is 6.5" from the bottom to the terminals.
I will be using door hinges to hold it together, and it has to have curves cut in it to form fit the strut bar.
Team CACO Team SHOK
Supporting Member
False Floor Amp Rack gbo559 General Car Audio Discussion & Questions 11 07-20-2009 03:00 AM
Amp Rack pics request! BlackWaterOp General Car Audio Discussion & Questions 10 07-03-2009 05:56 PM
Amp Rack RidnClean General Car Audio Discussion & Questions 12 01-24-2009 09:17 PM
Need Ideas for Amp Rack and Battery Rack! BassikInstincts General Car Audio Discussion & Questions 8 01-15-2009 11:36 AM
amp rack deal waresgaragestereo Build Logs 20 12-29-2008 12:51 AM
