Cheapest fiberglass resin? - Car Audio Classifieds!
Old 05-22-2015, 10:23 AM
Lock up your daughters!
0/11 sssss1342
Default Cheapest fiberglass resin?
Hey, I'm looking to buy a bulk amount of fiberglass resin. Would like to buy 10 gallons. I don't want poor-quality resin, but want to find the best deal I can, since I'm buying so much. Do you guys have a link to buy good-quality resin in bulk? I've done fiberglass before, but in a much smaller quantity.
Box is going to be a wall about 6 cubes gross and will also be doing my roof, back wall, and floor. Possibly custom fiberglass dash too, so I wanted a bit extra.
This is the best bulk deal I saw for 5 gallons:
Fiberglass Resin Polyester Lamanating 5 Gal Mekp Hardener | eBay
If you guys have any cheaper links, that would be awesome! Thanks!
Old 05-22-2015, 10:56 AM
Hdorre's Avatar
0/11 ssssss540
Polyester Resins
Their 435 layup is all ill ever use again.
5 gallons are $125 + ship
Old 05-22-2015, 12:16 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Check w electronicsoasis on here. He may be able to help
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 05-22-2015, 02:41 PM
bassman_soundking's Avatar
0/11 sssss2063
Originally Posted by Hdorre View Post
Polyester Resins
I plan to do some 1st time glassing of doors.
Can you tell me the differences you notice with different resins?
I need a H/O alt for my 2006.5 Scion xB
Sold to: Jonesy
Traded with: Jonesy, 310w6, Ciaonzo
Bought from: newtitan. T3audioNavi
Old 05-23-2015, 10:46 AM
0/11 sssss1342
Polyester Resins
Thanks for the link!
Old 05-23-2015, 03:12 PM
0/11 sssss1475
Very interested in an answer to this as well. I did my doors, wheel wells and box with the bondo resin from lowes. Never used anything else.
Advice I can give ya on your first set of doors that I learned.
1. Don't use fleece! Get a thin t shirt type material that stretches well.
2. Glass from the backside to reduce the bondo work for making it smooth.
3. Plan on everyone kicking your bottom woofers, I mean everyone! I tell people how much I hate it and they still kick it, pretty damn annoying. So make a grill and have extra glass on the bottoms.
The Following User Says Thank You to lunchbox For This Useful Post:
bassman_soundking (05-23-2015)
Old 05-23-2015, 04:19 PM
0/11 sssss2063
Yeah my youngest daughter will Definately kick it.
She is always putting feet on the dash etc...so pisses me off!!
Sold to: Jonesy
Old 05-23-2015, 05:59 PM
The bondo resin (and others that are not labeled as layup) have a small amount of wax that separates out to the surface when curing. This is helpful in having a non-tacky surface when you're done with the piece, but should be sanded off if you're using it in multiple layers with curing between the layers. I typically just lay down all the layers at once and don't worry about it.
Edit: Oh, and the bondo resin is probably the thickest stuff you can get. Not really a problem most of the time, but it can make proper wet-out difficult with thicker materials.
Best FiberGlass resin and mat? Haelmuscle General Car Audio Discussion & Questions 15 01-21-2015 04:44 PM
How much resin and fiberglass mat do I need? Kcbme General Car Audio Discussion & Questions 14 09-20-2014 10:10 PM
fiberglass resin between baffles Gmanguy Enclosure Discussion & Design Construction Help 4 05-31-2014 12:21 AM
Who has the cheapest resin?? nicholasmccabe Sound Deadening & Fabrication 12 07-03-2013 08:05 PM
Fiberglass resin ??? KHARPS General Car Audio Discussion & Questions 9 07-11-2009 05:03 PM
