got a design i need input - Car Audio Classifieds!
Old 05-28-2015, 03:04 PM
mr505's Avatar
0/11 ssssss327
Default got a design i need input
Hey guys so this design is for 2 12" shd subs let me know if this will work it's 2.25c.f. pre chamber tuned at 32Hz would appreciate any input thanks
Old 05-28-2015, 03:06 PM
209native's Avatar
0/11 sssss1975
maybe double the baffle them shds are gonna be heavy... how much power?
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 05-28-2015, 03:08 PM
mr505's Avatar
0/11 ssssss327
I will and they will be powered by 2 crescendo 3500s how do the specs look
Old 05-28-2015, 03:21 PM
209native's Avatar
0/11 sssss1975
the numbers look ok but im no pro I would wait on some more input. im sure someone has some good info on the shds
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 05-28-2015, 03:22 PM
mr505's Avatar
0/11 ssssss327
Okay thanks man hopefully someone good at this can approve so I can begin my box
Old 05-28-2015, 04:49 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Build it bro. Should slam. If you are running a single bc3500 per Shd then I suggest adding half a cube to each side. Might also remove the port divider and allow the woofers to share the port area, but that is just me. I'm an aero guy so all slots "look wrong" to me...lol
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 05-28-2015, 04:52 PM
mr505's Avatar
0/11 ssssss327
Well I'm going to out vert them and also one shd is old version and one is new they have different sort parts last box I made was in a common ported box and it seemed out of phase that's kinda why I'm having them in a separate chamber
Old 05-28-2015, 04:54 PM
SPL Farms
0/11 sssss5706
Ahhh, gotcha. You talk to Murphy about it?
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 05-28-2015, 04:57 PM
mr505's Avatar
0/11 ssssss327
Ya I talked to murphy he said it shouldn't matter but I did c a difference
Old 05-28-2015, 05:00 PM
209native's Avatar
0/11 sssss1975
was it acting out of phase or was one sub unloading?
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
box design and input BassMechanic308 (Sundown Audio) 2 11-05-2014 03:04 PM
Input on my box design? 6cyclones6 Enclosure Discussion & Design Construction Help 8 02-26-2013 06:49 PM
Input on box design for Hatchback mdaudio General Car Audio Discussion & Questions 12 10-11-2011 09:00 PM
Single 15 Box Design.Any input ? xpd442 Enclosure Discussion & Design Construction Help 9 04-02-2011 12:46 AM
Need input on this box design k3n12ock General Car Audio Discussion & Questions 19 02-24-2010 12:41 AM
