Aero port help - Car Audio Classifieds!
Old 06-21-2015, 03:24 PM
0/11 ssssss488
Default Aero port help
Ok guys need a little help. I have 2 zv4 15's and my box is 7.5 after subs and bracing,and I'm wanting to use aero ports as I'm limited on space. I have two 4" aero ports on hand. What size and length do I need to get 32 hertz tuning? Thank
Old 06-21-2015, 03:39 PM
0/11 sssss3526
If you plan to use 4" aeros you'll need at least 4, and that only gives you 6.9^2 which is shy, even for aero's. Even 5 only gives you 8.3^2
Can you fit 2 or 3 6"?
Old 06-21-2015, 03:44 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
4 4" ports minimum
2 6" ports minimum
-Youtube Channel
Old 06-21-2015, 03:55 PM
0/11 ssssss488
Thanks guys how long would 3 6" ports need to be
Old 06-21-2015, 04:10 PM
0/11 ssssss535
aero calc
Old 06-24-2015, 05:02 PM
0/11 sssssss24
Make sure you have enough to run the length required for your desired tuning.the bigger the aeroports,the longer you have to have them
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 02:08 AM
finding 10" aero port, port calculation help darkkon General Car Audio Discussion & Questions 6 07-24-2011 07:26 PM
