Tuning help - Car Audio Classifieds!
Old 06-22-2015, 04:17 AM
0/11 sssssss83
Default Tuning help
Okay I have 4 12's in a ported box. The box has two slot ports that are each 3" height, 25" long and 14 inches deep. I can only play 40hz all the way up to 60hz.... I want lows. 57hz is the loudest. I really want my tuning to be 32hz. Can someone please tell me how I could lower the tuning for them. Subs are 4 CT sound tropo version 2 12's. Box is about 11 cubes.*
Old 06-22-2015, 04:46 AM
0/11 ssssss403
do you have a pic of the box handy? also, is this a common chamber or is it split? knowing these things will help a lot.
Old 06-22-2015, 04:55 AM
0/11 ssssss247
Pic of the enclosure...inside of the enclosure also if you can...
Old 06-22-2015, 01:04 PM
0/11 sssssss83
There separate chambers. 2 subs has its own chamber
Old 06-22-2015, 01:06 PM
0/11 ssssss403
ok, so each chamber is roughly 28hz already. and i mean rough. could be lower with displacement, bracing, and what not. best bet is to do a total rebuild.
Old 06-22-2015, 01:08 PM
0/11 sssssss83
It won't let me upload a pic. Each port is that measurement that I gave. There's two ports for each of 2 subs. Inside the box the ports are almost touching the rear of the boxes wall. I want a tuning of 32 hz. Would I need to take some port away?
Old 06-22-2015, 01:10 PM
0/11 ssssss403
yeah, 17 inches seems to be the number for length. and im roughing this at 5.5cft a chamber with the 11 gross you gave us as a whole earlier.
Old 06-22-2015, 04:36 PM
0/11 sssssss83
So it can't be fixed ?
Need help with tuning. Austin175 Enclosure Discussion & Design Construction Help 3 03-20-2012 01:01 AM
tuning help? mrtopnotch561 General Car Audio Discussion & Questions 5 06-14-2011 10:30 AM
Tuning ?? Ground Poundin Jeff General Car Audio Discussion & Questions 20 10-05-2010 07:13 PM
tuning Austin175 General Car Audio Discussion & Questions 4 06-10-2010 08:01 PM
