burp box port area - Car Audio Classifieds!
Old 06-28-2015, 01:36 PM
doug118's Avatar
0/11 sssss4674
Default burp box port area
I'm building a "burp box" for my truck but not sure how much port area is too much? Box will be 6 cubes with either a single 10" or 12" aero. 12" is 18.84" per cube and the 10" is 13" per cube. I'm only tuning to 40hz since the truck peaks at 42. Question is, will the 12" port be louder and would it be safe to play music with that kind of port area? When I say music, I mean the typical songs used in db drag that are 40-47hz
Old 06-28-2015, 02:22 PM
0/11 sssss3526
What sub? A DD or an SQ/AQ would love a lot of port. Other Subs, not so much
Old 06-28-2015, 02:26 PM
doug118's Avatar
0/11 sssss4674
FI N3 with a concoction of soft parts
Old 06-28-2015, 02:29 PM
0/11 sssss3526
Keep in mind also that the efficiency of aero's allows for lower sq area requirement. So even 13^2 on an aero is quite a bit
Old 06-28-2015, 02:31 PM
mega fatty
0/11 sssss6008
I would make a changeable baffle and try both if it's spl
doug118's Avatar
0/11 sssss4674
I've been running aeros for a while now so I know about the port area for daily. I'm running just under 10" per cube now but that's for regular box. I'm looking for port area with a burp box. I think 13" is just at the upper end for daily use and I know more port area is usually best for burp boxes. Just don't know if 18" is too much
Old 06-28-2015, 02:43 PM
FocusOn20s's Avatar
'12 Focus Bangin
0/11 ssssss951
there's really no such thing as too much port area within reason
I'd do the 12"
2012 Ford Focus
Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
Old 06-28-2015, 03:37 PM
mega fatty
0/11 sssss6008
Sa8's use as much as 22sq " per
Sa-12s HELP!! port area? box size? burzendowski (Sundown Audio) 22 11-06-2012 01:34 PM
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 09:04 PM
Small box=More Port Area bcaz808 Enclosure Discussion & Design Construction Help 29 12-05-2011 06:43 PM
sa-8 box, tuning, port area, etc?? fyerbyrd22 (Sundown Audio) 15 01-23-2011 11:01 PM
how much does the port area affect a box?? westman995 General Car Audio Discussion & Questions 49 03-15-2010 02:49 PM
