Single 12 4th order - Car Audio Classifieds!
Old 06-29-2015, 06:50 AM
0/11 sssssss47
Default Single 12 4th order
Hey guys. I am going to build a 4th for a skar vvx 12 d4 v1. Max deminsions 29w x 16T x 23 deep. 1 cube sealed to 3 cubes ported. Sin glee six inch aero tuned to 45. That's the plan. I want it to be the best it can be so if anyone here can tell me how it cam be better please let me know. Depth can be longer by about 4 or 6 inches.
Old 06-29-2015, 08:33 AM
0/11 sssssss15
Go with an 8" port. I did a nearly identical setup only with an Obsidian 12, and tuned to 38. With a 6" port you just lose too much output. I used a sono tube but eventually switched to a regular slot port. If you don't flare the sono tube, you'll get some pretty ferocious port noise as the air moves around the hard edge on the ends of the tube.
I will say, I think a setup like you're talking is easily on par with a ported pair of 12's. It gets LOUD. My 4th was peaking at 32, but I was also tuned quite a bit lower.
Old 06-29-2015, 07:56 PM
0/11 sssssss47
With an 8 I would have to put a bend in the port it will need to be 24" to get down to 40 hz. I was also wondering about a big square port but the length would be nuts
Old 06-29-2015, 08:15 PM
mylows10's Avatar
0/11 sssss2210
Feedback Score: 17 reviews
Do the slot port
Old 06-29-2015, 08:19 PM
0/11 sssss1417
Your gonna tune a 4th for a single 12 to 40hz? I'd consider a higher tune, especially for a small setup.
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
Old 06-29-2015, 08:20 PM
mylows10's Avatar
0/11 sssss2210
I do mine at 45 hertz ported. 2.5:1 ratio. Slot port
Old 06-29-2015, 08:26 PM
0/11 sssssss47
Slot port takes a lot more space. Not sure I can keep a 3 to 1 in my space restrictions
Old 06-29-2015, 08:29 PM
mylows10's Avatar
0/11 sssss2210
Most important thing is to make sure the port can be modified if need be until you get your desired tuning
Old 06-29-2015, 08:30 PM
0/11 sssss1417
The 6" aero is way too small though.
Team Scoshe
Team Sears
stealth(Today)
Old 06-29-2015, 08:39 PM
FocusOn20s's Avatar
'12 Focus Bangin
0/11 ssssss951
yeah for my single 12 (American Bass XFL), I tuned to 45 hz 2.5:1 ratio with an 8" octoport
2012 Ford Focus
Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
4th order for single nsv1 15 Gmanguy Enclosure Discussion & Design Construction Help 12 05-16-2014 08:26 PM
single sa15 4th order tattoonick87 Enclosure Discussion & Design Construction Help 3 09-28-2012 07:44 PM
single sa15 4th order tattoonick87 Enclosure Discussion & Design Construction Help 0 09-26-2012 10:06 AM
Help on a single 10" 4th order? tandrel Enclosure Discussion & Design Construction Help 2 04-09-2012 11:44 PM
Single 15 and 4 10 4th order boxes ltr450racer690 Wiring, Electrical & Other Installation Equipment 32 04-23-2011 11:11 AM
