Comment on this small box I designed - Car Audio Classifieds!
Old 07-08-2015, 11:07 PM
0/11 sssssss85
Default Comment on this small box I designed
I'm trying to come up with a small box I can use for a pair of 8's. Sealed seems pretty straight forward. However ported should give me more low end and SPL for a bit more space.
I've been using the online calculators, and downloaded sketchup.
This is roughly 1.2 cuFt @29.5 Hz.
If anyone sees any inherit problems or has any comments about modeling a common chamber enclosure (I've heard a common chamber models as 10-15% larger per extra driver) I'd appreciate some feedback.
Old 07-09-2015, 12:12 AM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
What is your port area? I cant see the measurements they are too small on my phone
Old 07-09-2015, 12:13 AM
Ryan1126's Avatar
0/11 sssss9178
Weird sub and port orientation what is the box going in and what drivers are you using and on what power?
Old 07-09-2015, 12:23 AM
I'd raise the tuning up to around 35hz and increase the port area a bit. I'm assuming you need the port exit on the front, but if you don't I'd move it to one of the corners so you don't have that weird 90 degree turn at the port terminus. That being said, it looks great as it sits and should perform well!
Old 07-09-2015, 12:24 AM
0/11 sssssss85
Port area is 13 Sq in. Subs are Infinity reference 860w. Spec sheet calls for 2 1/2 in round port, which is about 5 Sq in per sub.
Old 07-09-2015, 12:26 AM
0/11 sssssss85
Subs and port will be firing into the cabin of my brz. (back seat folded down kind of thing.)
Subs are Infinity reference 860w, running in parallel at 2ohm. At that impedance my D600.1 is rated @450W.
Old 07-09-2015, 12:29 AM
0/11 sssssss85
Playing with Winisd gives a flatter response with this tuning. I will plug in 35 and see what it does, but I'm guessing I'll get a pretty big hump.
I could make the box a bit deeper and open up the port a bit. But it's already bigger than I wanted to be. I'm not sure what the 90 degree turn will do, but with the enclosure visible in the cabin I got to keep the symmetry!
Old 07-09-2015, 12:42 AM
Ryan1126's Avatar
0/11 sssss9178
I would just suggest a "T" port
Old 07-09-2015, 12:49 AM
0/11 sssssss85
I would love to try that. Happen to know of an online calculator or have any pointers?
Old 09-07-2015, 10:00 PM
0/11 sssssss85
Wow, started this two months ago!
Just thought I'd update. The box got a bit shorter and a bit deeper. I had some scrap construction wood laying around. This was supposed to be a quick test box, but since it has taken me this long I'm hoping it works.
I still need to run some wiring in the car, but the box is close to having drivers installed.
Box I designed for a HDC412. Will it work? 99bblazer99 Enclosure Discussion & Design Construction Help 8 08-27-2014 03:45 PM
Need a box designed, $$ involved of course. nicyousuckk General Car Audio Discussion & Questions 5 09-19-2011 12:53 AM
I need a crazy box designed for me littleharv93 Enclosure Discussion & Design Construction Help 2 07-18-2011 02:11 AM
most PITA box I have ever designed korey_hofer Enclosure Discussion & Design Construction Help 18 12-15-2009 08:56 PM
Check this DD designed box design? da box king Enclosure Discussion & Design Construction Help 8 08-16-2009 07:54 PM
