aeroport size - Car Audio Classifieds!
Old 07-11-2015, 08:05 PM
0/11 ssssss600
Default aeroport size
I probally should have just posted it here but is a 6" aeroport ok for two infinity 10"subs or should I get a smaller port? the box will be about 3 cf
Old 07-11-2015, 08:22 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
I would venture a guess without knowing the Infinity in question, you may have a hard time pressurizing that size port. That being said, you can always shrink the area with a partial plug.
Old 07-11-2015, 09:12 PM
0/11 ssssss600
They are just the 1062w 10" subs
So it might be to big is what you're saying...... damn. I used another 6" port for a sundown 12" z4 and it worked great. That sub does have 3x the xmax though......
If I had the cash I would sell these subs and buy something better/bigger but
Old 07-11-2015, 09:53 PM
0/11 sssss3526
That's 9^2 which is an OK # for an aero. I would think it would be OK. How much power?
Old 07-11-2015, 10:11 PM
0/11 ssssss600
a jl 500/1v2
I was playing with the Torres box program and saw a 4" port would be better because I could have the port much shorter for my 33hz goal. would a 4" be ok also? how do I find that number?
Old 07-11-2015, 10:31 PM
0/11 sssss3526
At 3cu that's only 4.2^2. A 5" port would be 6.5^2 if you can find or make one
Old 07-12-2015, 12:09 AM
jeffdachef's Avatar
0/11 ssssss440
Originally Posted by lalojamesliz View Post
a jl 500/1v2
Find the Xmax of your infinities and use this to find the minimum amount of port area you need Car Audio - PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES
Old 07-12-2015, 02:26 AM
0/11 ssssss697
For what it's worth, I used a 6" aero for 2 sa 10s and it worked great
2001 Tahoe
2 24" tantric SHD
2 American Bass 1100.1
Old 07-12-2015, 02:45 AM
0/11 ssssss600
the xmax is 13mm http://www.crutchfield.com/S-Zjmn4A0...ity-1062w.html and the xmax on the sa-10's is 19mm.
ill look for a 5" port and ill check out that link jeff.
I never knew how inefficient the jl amps are until earlier.
can you guys recommend me a amp that will be great for these subs on a 4 ohm load for about $240 or less? I don't like it that these subs are dual 4 ohm each. the rms on each sub is 275
Old 07-12-2015, 02:59 AM
0/11 ssssss600
yeah, that 5" aeroport isn't going to happen parts express let me down this time...
2 PWX-6.5 8ohm mids, Need help with box volume and aeroport size Potsy1 Enclosure Discussion & Design Construction Help 7 06-01-2015 09:44 PM
copper lug/ring terminal hole size and tech flex size? mrtopnotch561 General Car Audio Discussion & Questions 4 01-16-2014 09:12 PM
2 SA-8's, What size/qty of aeroport(s)? joebobclark (Sundown Audio) 32 05-14-2012 11:26 PM
aeroport size for 15'' fi ssd AndrewBR98 Enclosure Discussion & Design Construction Help 4 08-02-2011 07:10 PM
Does aeroport size matter? Nebraskachevy General Car Audio Discussion & Questions 13 10-24-2010 09:44 PM
