thoughts??? - Car Audio Classifieds!
Old 07-15-2015, 02:25 PM
noknok's Avatar
0/11 sssss1521
Default thoughts???
This is the basic layout that I came out with. What are yalls thoughts? Going to have 4 18s on about 2k and 4k burps
Old 07-16-2015, 01:22 AM
Damn, there's like NO more room on that baffle, lol. Are you planning to laminate a bunch of sheets together to get the port depth or use something else? Should be killer!
Old 07-16-2015, 08:49 AM
noknok's Avatar
0/11 sssss1521
Got a teammate that does metal fabrication.. Port might be made of 16gage steel.
Old 07-16-2015, 11:44 AM
16ga will resonate like a son of a bitch
Old 07-16-2015, 12:50 PM
noknok's Avatar
0/11 sssss1521
I was planing on coating it with something.. Maybe plastic or rubber idk how the rubber would do though.
Old 07-16-2015, 12:58 PM
noknok's Avatar
0/11 sssss1521
I figured steel would work since psychopaths uses steel tubing and there awsome ports.. Was my easiest option
Old 07-16-2015, 02:41 PM
His is spiral round pipe that's much stronger. Hell even 10ga would resonate and it's 1/8th" thick.
The Following User Says Thank You to korey_hofer For This Useful Post:
noknok (07-17-2015)
thoughts?? newarkbeast973 Off Topic Chat 0 03-11-2012 07:05 PM
Your thoughts? davecubs14 General Car Audio Discussion & Questions 10 07-01-2011 02:19 PM
what are your thoughts on... newarkbeast973 General Car Audio Discussion & Questions 9 09-01-2010 10:17 PM
what are your thoughts on xjoeyc23x General Car Audio Discussion & Questions 12 06-03-2010 10:38 PM
Thoughts on this... strpperpolef150 Enclosure Discussion & Design Construction Help 22 01-01-2010 05:19 PM
