Dd9515 (x2) build help - Car Audio Classifieds!
Old 07-19-2015, 10:19 PM
Sgt_76's Avatar
0/11 sssssss51
Default Dd9515 (x2) build help
Been quite a while since I've been on here. The old plan was to wall my 85 vetted with these but I sold it to help fund a new business venture. I'm tired of everything just sitting piled in the closet so it's time to do something with it! The plan is put them in my work Truck (2008 dodge ram 2500 quad cab). If I pull the "60" side of the 60/40 rear seat it gives me roughly 36"W x 32"H x 28"D to work with so plenty of space. My problem is I haven't messed with Torres in so long I'm having fits with getting a design figured out. I can build anything but the design part is getting the best of me. Any help with design part would be greatly appreciated.
-I'm completely open on sub and port orientation.
-slot or aero ports/sonotube.
-was looking at ~10cubes net tuned to 36-37.
-will be powered by sk-4500.
-looking for loud, and some low authority, but not just a complete low monster.
Old 07-19-2015, 10:20 PM
Sgt_76's Avatar
0/11 sssssss51
Guessing you can't post pics from mobile? Trying to post pic of what I have in Torres so far. I'm stuck using my cell to post because my laptop won't connect to the Web for some reason... So this is what I have...
-Subs up, Port firing forward... Centered with the floor the only common wall.
-38W x 32H x 28D (all 4 sides & bottom 1.5", top/baffle 3".
-port (17H x 10.75W x 19L)
Torres says 10.13 gross (I used 0.48 for sub displacement, and 0.05 for bracing), tuned to 36.98, 182.75 Sq in of Port, 18.04 port per foot.
Something is wrong though I think because torres says there's a port bend but the box is 25" deep (inside), and the port is only 19" long (only 17.5" would be inside though due to the wall being 1.5" thick). Am I missing something?...
F/S DD9515 $350dlls doc289 15" Subwoofers 7 03-28-2012 06:00 PM
(2) dd9515 ldyzluvdis06 15" Subwoofers 7 02-03-2011 02:07 PM
Dd9515? Ryan1126 General Car Audio Discussion & Questions 46 12-17-2009 10:32 PM
