First time using Aero's, is this enough port? - Car Audio Classifieds!
Old 07-20-2015, 02:04 PM
The_Dealer's Avatar
0/11 ssssss212
Default First time using Aero's, is this enough port?
I'm thinking about going with Aero's to keep the overall box size down for 3 Diamond Audio D3 10's. I'm shooting for 32-33hz and 4.4-4.6 net. Torres says with 3 4" Aero's it will put me around 8.5"^2per cube. That gives me the tuning I want and they'll fit the box with a ports width from the box wall. Is this enough port area for them? I'm wanting to run them on 1800w rms. They're going in a Jeep liberty, so port noise would be pretty noticeable. If I tried to run 2 6" my tuning would be a lot higher than I want. Should I just go with a slot port instead?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 07-20-2015, 02:41 PM
mega fatty
0/11 sssss6008
I think you should be fine with 3 4"
How much does your tuning go up with the 2 6" aeros?
Old 07-20-2015, 11:34 PM
The_Dealer's Avatar
0/11 ssssss212
It goes from 32.75 to around 39 according to Torres. Pretty big jump
Old 07-21-2015, 01:13 AM
KickinBlazer's Avatar
0/11 sssss1122
y not add a 4th aero....for SPL and simply plug 1 for daily..lol
if its to loud your to old!
Old 07-21-2015, 07:04 AM
massivespl's Avatar
0/11 sssss8409
I think 3 4" aeros will be good for those woofers.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 07-21-2015, 07:58 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
Yeah the average 10 is good with a 4" aero per, 8.5 Sq. In per cube is pretty common when referring to aero ports.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 07-21-2015, 10:39 AM
The_Dealer's Avatar
0/11 ssssss212
Sweet, gonna go pick up a sheet of birch and get on it. Thanks guys
Old 07-21-2015, 10:47 AM
The_Dealer's Avatar
0/11 ssssss212
If I didn't burn the coil on one them I would've added a 4th port...to go with the 4th sub. Just added another run of 1/0 and an Odyssey PC1500, so I guess I'm going to find out how much smoke my VFL120.1 will make running at 0.67ohms.
first time aero port noob Gloostik Enclosure Discussion & Design Construction Help 10 06-17-2013 12:02 AM
First time Aero Port User help Burbarry Enclosure Discussion & Design Construction Help 23 02-22-2012 03:37 AM
finding 10" aero port, port calculation help darkkon General Car Audio Discussion & Questions 6 07-24-2011 07:26 PM
