make straight cuts = eazy - Car Audio Classifieds!
Old 08-05-2015, 11:23 PM
0/11 sssss1411
Default make straight cuts = eazy
you need = a pair of c clamps of some sort - and a long straight edege.
it can be a piece of random scrap metal / or wood as long as its straight - and at least as long as the cut you need to make.
i have a 60" inch ruler (avalable at home depo for cheap) at work and i use that. - pix win so here goes.
i wanted to cut my plywood to 95 inches - so you can see the cut mark at 95" as well as a second mark at 93.5" as the guide on my saw is exactly 1.5" away from where my blade starts cutting materials... your saw may be diffrent than mine so you will need to check and measure how far your blade sits in from your saw guide edege and use that measurment as your second mark.
get all lined up and square with the saw before starting your cut - making shure to double check the edege is clamped on how you want it.
start the cut and keep the saw guide plate pressed up against your straight edege as you cut - dont let the saw walk off keep firm preasure against your guide edege
finish the cut and sand off any rough burr and boom - eazy peazy nice cuts
also fyi this below pic = yes for acurate measuring
this pic = NO for acurate measuring and marking
i kno that last pic is an exaguration of measuring off center or un square but it happens all the time to a lesser extent. its important to keep paralell to your work as you pull a tape across as swinging it left to right will actually ark like a pendulim and give un acurate markings to cut to.
The Following User Says Thank You to brian84corvette For This Useful Post:
Homernuts (08-06-2015)
Old 08-05-2015, 11:35 PM
0/11 ssssss822
im sure alot of ppl will thank you including me for the tip. thanks
01 tahoe 80prs
275 & 350 singer alt
2 black cherries
levi iii
2 12's dds tridents
4 cf 8's & vifas xt25's
Old 08-05-2015, 11:37 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Tapatalk needs a post thanks button....that's awesome man...
Just Sent
Old 08-05-2015, 11:57 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
I also made a thread called cutting wood for dummies that is very similar to this. Happy to see people using the same method
Old 08-06-2015, 01:58 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Same simple method used for routers....and maybe jigsaws too.
I always use the method measure twice, cut once.
While that long scale is ideal, I would strongly suggest a thicker piece of material such as mdf or something like 3/4" thickness. I've ran into the problem where since those 3 ft. rulers are kinda thin and the circular saw has a rounded edge, it can easily go off track if your not paying attention.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 08-06-2015, 04:05 AM
0/11 ssssss171
These are cool too
New 50" Clamp Cut Edge Saw Guide Woodworking DIY Application Swivel Pad 66581 | eBay
Harber frieght had one on sale for 20 bucks a few months back
Yocom
Old 08-06-2015, 05:58 AM
Micksh's Avatar
0/11 sssss2596
This is the one I have, I've used the Harbor Freight one too. It works fine, but this one clamps a little straighter easier, IMO. It's more expensive, obviously too.
http://www.amazon.com/E-Emerson-Tool.../dp/B003TXSAHU
My Youtube page
Astro build log link
Old 08-06-2015, 06:06 AM
0/11 ssss12531
^^That thing isn't adjustable??
That's a downfall.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 08-06-2015, 06:21 AM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
That's a downfall.
Reading the comments, says yes it's adjustable.
I spent the extra on a track saw though.
Old 08-06-2015, 09:06 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
Empire 98 in. Professional Cutting Guide-E902 - The Home Depot
Best purchase for cutting IMO.
Current Build:
#60sHereIcome
anyone listen to G-eazy? Ryan1126 Off Topic Chat 8 10-04-2014 04:44 AM
Bone Thugs & Eazy E Hologram k3n12ock Off Topic Chat 13 09-10-2013 02:13 PM
straight cuts? CousinVin Enclosure Discussion & Design Construction Help 20 11-14-2011 02:08 PM
How do you get straight cuts? silvercookie Enclosure Discussion & Design Construction Help 26 06-20-2010 05:23 AM
Squaring Cuts to make before you start building a box. iamsonic Tutorials & Quick References 0 07-25-2009 08:48 AM
