2 sundown x-18's in civic - Car Audio Classifieds!
Old 08-07-2015, 11:34 PM
0/11 ssssss245
Exclamation 2 sundown x-18's in civic
Building a wall in my two 2002 civic coupe for 2 sundown x-18s. It will be ported and each sub getting 2k for power. Any suggestions on volume and port? Port middle, top or bottom? I will build into the trunk to get the airspace I need. I want to tune it to 30Hz.
Old 08-07-2015, 11:47 PM
bassman_soundking's Avatar
0/11 sssss2063
I think recommended is like 7FT^3 each
I need a H/O alt for my 2006.5 Scion xB
Sold to: Jonesy
Traded with: Jonesy, 310w6, Ciaonzo
Bought from: newtitan. T3audioNavi
Old 08-08-2015, 12:24 AM
0/11 sssss1417
Sundown site says 14 cubes net. 224 sq inches of port. You're looking at 20 cubes gross tuned to 30hz. Idk if that helps.
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
Old 08-08-2015, 02:56 AM
0/11 ssssss245
Yeah, I have the specs here but looking for tips more on port location and box size and tuning with the small cabin space. This is my daily beater I drive to work so I'm not worried about a tl score but I want it to sound good with doors and windows closed.
Old 08-08-2015, 07:46 AM
mega fatty
0/11 sssss6008
i like center or top port for daily drivers, but you can still get great sound from port on driver side
build the shell as big as you can then put the baffle where it needs to be for the space. then if you want to upgrade ever you dont need a full rebuild
07 mazdaspeed3
rd d9 @ .5ohm
The Following User Says Thank You to tymoto21 For This Useful Post:
expo615 (08-08-2015)
Sundown zv4 12's 153+ from honda civic myjaja (Sundown Audio) 47 10-14-2014 12:18 PM
Honda civic build with sundown zv4's and 7000 watts myjaja Build Logs 70 10-05-2014 09:09 PM
Sundown powered Civic w/ 15" kmanian1 Build Logs 15 01-25-2011 10:06 AM
Does anyone have a Honda civic or civic/si 2006-2010 or Audio_Prodigy General Car Audio Discussion & Questions 1 09-17-2010 10:37 AM
First build: 89 Honda Civic Hatch (2 18s + sundown 3500) Vasilios Build Logs 56 09-07-2010 05:21 PM
