Opinions on a 4th order - Car Audio Classifieds!
Old 08-10-2015, 10:10 PM
skinnyg's Avatar
0/11 ssssss828
Default Opinions on a 4th order
Your guys opinions on a lil bandpass action here. My cars trunk is huge, I bet I could build a 12 cube box in there if I wanted to (02 Chrysler Concrete), but that defeats the whole purpose of me buying this big ass car, so I would have room for me and my daughter to travel.
Anyways down to it, the rear seat is leather, doesn't fold down, there is a steel enclosure for the rear deck speakers that hangs down about 4" from the rear deck itself. So I'm limited to 14h 38w and 20d I'm willing to give up. Gives me 6.16 gross outside volume, I was thinking 2 10s 1 cube sealed, 3 ported, I can go a little bigger on the depth, 2 10s work the best? Bump it up to 1.5 sealed 4.5 ported? My armrest is 8w 8.5h. Opinions?
edit- also opinions on both subs in a common sealed chamber firing forward into a common ported or 1 sub in their own sealed chamber firing into a center common ported.
I haven't bought subs yet, I will be buying matching motors then building the subs, 4th order friendly of course, and I'll have 2-3k, 3k being the most.
Thanks everyone in advance! Lots of knowledgeable people here.
Sent from my SM-G900P using Tapatalk
Old 08-10-2015, 10:17 PM
skinnyg's Avatar
0/11 ssssss828
Or what about 1 sealed 4 ported, or is that enough for 12s? Or would 10s be better in a larger box than 12s in a smallish box?
Old 08-10-2015, 10:19 PM
skinnyg's Avatar
0/11 ssssss828
Won't let me edit
Not sure if I can fit 12s vertically, I would have to angle the baffle
Old 08-10-2015, 11:03 PM
Turn it up's Avatar
0/11 sssss1933
i say 2 10s with the space you have available. im in the same boat i want to use 2 Sundown X 12s in a 4th order and ive been playing around designing the enclosure in sketch up and the box is huge its bout 16h 35w 30d lol and its only bout 2 cubes sealed 4.5 ported so bout 2.5:1
Old 08-11-2015, 06:51 PM
skinnyg's Avatar
0/11 ssssss828
Damn that seems big on the sealed side, but i guess you have some tsp to go off of, I dont, yet. I plan to pull them with a wt3 after i get the subs, of course they will have 4th friendly softies, what that consists of is beyond my knowledge. But that does make me feel a lil better, I was guessing with the space I have 2 10s will work the best. I can go way deeper like 40 but I dont want to build it in car first of all, I dont want to cover up my spare, and I want my room! Thats why I sold my 18 I had in the last car.
Sent from my SM-T217S using Tapatalk
Old 08-11-2015, 06:53 PM
skinnyg's Avatar
0/11 ssssss828
Edit- my bad, i see you have 12s, not 10s, seems about right
Old 08-11-2015, 07:10 PM
0/11 ssssss543
Spend the money on some x10's or build with sundown 10 baskets and cones they are a little larger than standard 10's around 11in and should still fit inside your box.
Old 08-11-2015, 07:19 PM
Turn it up's Avatar
0/11 sssss1933
yea but modeling up the box in bbp6 i get a big peak at tuning but ive heardd thats just reference point response will change in car with cabin gain etc
this or one x12 should get nasty
Old 08-12-2015, 11:28 AM
skinnyg's Avatar
0/11 ssssss828
Was thinking 1 15 actually, but Im limited to 14"h underneath my rear deck
Opinions needed, 6th order two nsv3 18s or three zv4 18s 4th order???? Mnorwood01 (Sundown Audio) 8 03-03-2014 11:24 AM
Final 4th order design - Opinions welcomed stssilverado Enclosure Discussion & Design Construction Help 5 03-02-2013 09:39 PM
4th order opinions and need constructive advice:D KEVGNAR Enclosure Discussion & Design Construction Help 3 03-02-2013 02:06 AM
Opinions on this 4th Order power-fanatic Enclosure Discussion & Design Construction Help 5 03-31-2012 10:03 PM
