DD Z 6th order help! - Car Audio Classifieds!
Old 08-12-2015, 09:29 PM
Lock up your daughters!
0/11 sssss1342
Default DD Z 6th order help!
I haven't posted a build log here, but might if people are interested. I have a 2007 Silverado Crew cab that I took the back seats out of. I currently own two DD Z 12's, but will be getting them re-coned into 18's after I sell my other subs.
I've been doing some thinking. Below the window line in the back, I have 34 cubic feet with both front seats pushed all the way back and at my normal angle. That's way more room than I need for two 18's. I saw this and it got me interested:
Who could design something like this?
DD recommends 6.5 cubes for 18" Z's in ported boxes. I'd say I could maybe squeeze 30 cubes of actual airspace out of a 6th order. I'd just like to be able to play 25-70 hz with authority. I want relatively flat and good low end response, but also want to be as loud as possible with these two subs.
If anybody has experience with 6th's or knows somebody who does, would I have enough room for one?
Old 08-13-2015, 09:16 AM
0/11 sssss1342
Bump, need some advice or contact info for anyone who could design it.
Anyone know what ratios are good?
Old 08-13-2015, 09:36 AM
massivespl's Avatar
0/11 sssss8409
Ram designs. BHE are acouple box designers
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-13-2015, 10:19 AM
0/11 ssssss463
what are your max dims? i'm bored
Old 08-13-2015, 11:01 AM
0/11 sssss1342
Have heard of Ram Designs. Do they have a website or do you have contact info for them?
Also, Excessive Amperage never emailed me, so I'm going to call them today
63" sideways across the bottom. 42" front to back on the bottom. 34" front to back on the top. 24" of height to stay under the window line. I am willing to go higher if need be. Already got the floor cut:
Old 08-13-2015, 11:22 AM
0/11 sssss1342
Just emailed Ryan at Ram Designs. Hopefully they can design one for me
Old 08-13-2015, 11:40 AM
0/11 ssssss463
less than 25ft^3 with those dimensions. too small for an effective 6th in my opinion.
that's double walled 1.5" on all panels
Old 08-13-2015, 11:43 AM
massivespl's Avatar
0/11 sssss8409
Do a 6th with the 12s u got
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following User Says Thank You to massivespl For This Useful Post:
adulbrich (08-13-2015)
Old 08-13-2015, 11:47 AM
tboorn's Avatar
Fi Enthusiast
0/11 ssssss343
i too concur with that, you could build a fully optimal 6th with the 12s rather than trying to make it work with the 18s... space makes bass
Fidelity--Built To Last--Team Sound Asleep
I've never, not one time, seen a gain from 45's. People think of ports as a wind tunnel. They don't work that way. They resonate. They don't produce wind. If it was a wind tunnel, 45's would be more than justified. But it isn't.
Old 08-13-2015, 12:36 PM
97maxima's Avatar
Loud Trunk?
0/11 sssss1812
Yea i dont see it happening effectively, maybe 15s. if you went 12-16 in the rear that leaves you upside down for your front chamber and the port you will need
Direct Sound Solutions-Taramps-DC Power-Team Loud Trunks
Refs:too many to list
The Following User Says Thank You to 97maxima For This Useful Post:
Arizilla (08-13-2015)
Tags
bandpass, dd z, digital designs, silverado, sixth order
4th order or 6th order kingtidis Enclosure Discussion & Design Construction Help 5 05-29-2011 11:05 PM
