sundown x8 bandpass help - Car Audio Classifieds!
Old 08-15-2015, 01:31 AM
0/11 ssssss512
Default sundown x8 bandpass help
from my understanding a 3-1 ratio gives the best output with a wide bandwidth also?
if that is the case what should my ratio's be to build such a box and what should the ported section be tuned to?
have a pair of these x8s and a 2.5k amp wanting to a bandpass in my eclipse with port facing into the cab.just need a little help with ratios and tuning so i can figure out my enclosure dimensions
Old 08-15-2015, 08:53 AM
Turn it up's Avatar
0/11 sssss1933
We cant give you the perfect answer so youll have to do some testing.i would start with around .8 to 1 cube for the sealed side for both & 2.5 for the ported side you need to do a removable port to test different tuning frequencies start around 46hz
Old 08-15-2015, 10:15 AM
0/11 ssssss512
so 1 cu sealed and 2.5 ported for both woofers? so that would be pretty much my entire box thats still pretty small so i should be able to work with that.
i had wanted to do a removable port anyhow. but thanks man ill try this and see what happens
Old 08-15-2015, 10:23 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Are you doing a 4th order or a series 6th? How do you want it to sound?
Old 08-15-2015, 10:37 AM
0/11 ssssss463
From what I've seen using winISD the bigger the ratio the "peakier" it becomes.
Old 08-15-2015, 10:57 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I've done a decent amount of bandpass designs. I usually don't go over a 2:1 ported:sealed ratio and have had great success doing 1.5:1 ratio's.
I'm going to see if I can tell you exactly what I'd do.
Old 08-15-2015, 11:04 AM
0/11 ssssss512
my goal in this build is to surprise the hell out of people currently it already does being there x8s in a ported box on 2k but id like something more and id also like the woofers to be more protected.
my car is an 08 eclipse so its a hatch but my plan with a bandpass is to have it firing into the back seats and taking up as little trunk space as possible i plan to use a already glassed framing piece to actually use all available space " theres a metal framing section then goes right between the coil over towers"
i listen to everything from decaf to metal im after overall sq with a bit more output id like to dig deeper and play flatter with a wider range as well
Old 08-15-2015, 11:36 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
What are your dimensions?
Old 08-15-2015, 12:08 PM
Why are you going bandpass? I've got a box design you could try. It's an 8th order originally designed for a w7 but I think the c would work better
Old 08-15-2015, 08:41 PM
0/11 ssssss512
and u think that would work well with what im after here? lets see that design
Fi Q 10 Bandpass papasmurf96 Uninterrupted Build Logs 3 11-07-2013 11:45 AM
M2 8's in bandpass? sheldonfromltown (DC) 8 04-22-2012 06:30 PM
Dual Sundown Zv.3 18" Bandpass 98GMC General Car Audio Discussion & Questions 4 01-26-2012 08:54 PM
Bandpass basshead08 Enclosure Discussion & Design Construction Help 5 03-17-2010 03:09 PM
Bandpass help bdufner Enclosure Discussion & Design Construction Help 7 09-05-2009 07:50 AM
