First attempt on designing enclosures - Car Audio Classifieds!
Old 08-15-2015, 09:46 PM
0/11 sssss1882
Default First attempt on designing enclosures
So I've been looking more into designing my own enclosures and learning about them. I know the general rules of port/cube, aero, slot, etc. I'm not chasing any 4th/6th orders/walls. Just a plain old aero box.
Still learning to use sketchup so I don't actually have an image yet but it should be pretty easy to follow.
IA 21" at .5 nominal off a 2K. [sq2200, ia 20.1, ect ect.]
My dimensions are 41W x 22T x 23D. 2 6" ports, 12" long.
~28-31hz tuning, ~8.4-9 cubes net. .25 for woofer displacement, and an estimated .5 ft^3 for bracing. 1" dowel rods, top to bottom and front to back. Double baffled naturally. [net enclosure varies based on which calculator I used. They are all pretty close to each other though)
On paper, the port to cube is abysmal (6 inches/cube). After modeling with Win ISD and Bassbox, they're both showing pretty similar results with a peak port velocity of 26 M/S, which is within the "no port chuff" general guidelines.
I am also finally using the metal flares I got from chauncey forever ago. IIRC, they add about 1" to port length, not that 2" is going to drastically change anything. I thought it would help with the airflow really [and I have them/6" PVC laying around].
My goals are wide bandwidth and authority in the subsonic region. I've never been down there much, and am interested to see the general output of extending my bandwidth. I do not want to worry about unloading, etc etc. If any of you read my posts, you've probably seen this 100 times by now.
I've been told that I should build a larger box, with a smaller port, and mediocre power if I want to get where I'm heading.
Thoughts?
I've also plugged in 2 8" ports @ 20" long for a ~32-34hz tuning with 11" port/cube. Obviously the smarter choice for general guidelines, but I'm looking to play down to at least 25 hz, hoping for 20. That much port has me thinking it would unload pretty quick. Would bring box down to ~8 cubes.
Either way I think I will incorporate a swappable port piece on it to play with things a bit more.
As far as orientation goes, would I be better off with ports towards the corners, or centered next to the sub on either side? As far as I know I don't want it directly underneath the sub due to loading/phasing issues. Shouldn't it be as far away from the sub as possible?
Any insight and opinions welcomed.
I'm trying to start simple without building 10,000 boxes.. subs supposed to ship on the 25th. I want to get an idea on what I should be looking at here. Sub up, port back in a 96 Jeep Cherokee [box] loading off the [soon to be reinforced] hatch.
Thanks.
Old 08-15-2015, 11:41 PM
Silver03gt's Avatar
0/11 ssssss687
For sketch up, if you export 2d model you can save as JPEG or whatever file you want and be able to upload to photobucket and post that way.
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
Old 08-15-2015, 11:55 PM
0/11 sssss1882
I meant im learning to draw in sketch up. Never used any rendering software so its a bit of a learning curve for me.
Old 08-16-2015, 03:48 AM
jeffdachef's Avatar
0/11 ssssss440
Thoughts?
Thanks.
If the Meters per seconds checks out on winisd with your inputted amount of power then you should be relatively fine. If you plan on throwing even more power at it, the port will need to be bigger though.
Ever thought about doing a 10 inch sonotube? Extending 5 inches if possible
Old 08-16-2015, 06:12 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
You sound like you are on the right track. Is it a Death Penalty?
Another thing you must consider is low end bass needs a lot of electricity to power it. So make sure you have a bunch of juice behind that amp.
Old 08-16-2015, 07:49 AM
0/11 sssss1882
Forgot to mention, yes it is a death penalty.
Also, i was looking at the 10" sonotube but i literally cannot get it anywhere near where i am. I found a few places to order online but i think im going to avoid it honestly. Theres no telling if i will get anything actually close to 10", or the quality.
As far as higher power goes, should i be looking at a larger amp? Figured 2k would do as im building a relatively large enclosure with a smaller port.
Old 08-16-2015, 07:59 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I'm not a fan of running low ohm loads like that really. But what I meant is that if you don't have enough alternator and batteries, you won't have enough electricity to produce those heavy lows.
Old 08-16-2015, 08:54 AM
0/11 sssss1882
Oh gotcha. I have a mechman 320 and 100ah of kinetik right now. I plan on adding another ~150-200ah before i finish the build.
If im running anything i make sure my electrical is in check. good looking out, though.
Old 08-16-2015, 09:47 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Well then you're probably golden.
Old 08-17-2015, 01:13 PM
0/11 sssssss85
I had never used sketchup (or anything like that) before. I found a couple of videos on youtube specifically for drawing up sub enclosures. Made the learning curve pretty short without having to figure everything out myself.
Designing Enclosures: Tutorial Pioneer~Saturn Tutorials & Quick References 36 05-15-2014 08:22 PM
What software to use for designing Subwoofer Enclosures Jdubs04ss Enclosure Discussion & Design Construction Help 4 04-19-2011 06:29 PM
First attempt at fiberglassing... matt_2_2011 Miscellaneous Build Logs 20 05-17-2010 07:52 PM
1st Attempt...... KickerCobalt Off Topic Chat 13 05-15-2010 04:58 PM
