12 4th order or 15 ported - Car Audio Classifieds!
Old 08-17-2015, 07:11 PM
KickinBlazer's Avatar
0/11 sssss1122
Default 12 4th order or 15 ported
What would you run?....sub will either be a modded trf 12 or trf 15 the 12 would be in a 3:1 4th order the 15 would be in 3.25 cube ported at 33hz...powered bye a xxv cyclops at 1 ohm or less
if its to loud your to old!
Old 08-17-2015, 07:13 PM
Lock up your daughters!
0/11 sssss1342
15 ported.
The only reason I'm doing a 4th is because I have a lot of space and two motors.
2 12 4th order or 2 15 ported Ringspun09 Enclosure Discussion & Design Construction Help 10 12-08-2011 11:05 PM
4th order or ported theking General Car Audio Discussion & Questions 27 10-18-2011 05:58 PM
ported and 4th order? Russellabt General Car Audio Discussion & Questions 3 10-11-2011 01:06 PM
4th Order BP or Ported Parker G General Car Audio Discussion & Questions 16 11-25-2009 02:20 PM
