Some wall help - Car Audio Classifieds!
Old 08-20-2015, 04:33 PM
0/11 ssssss316
Default Some wall help
It's a early 90's 2-door Acura Integra hatchback,walling it with two Team FI 18's on 9-10k amp. I'm shooting for a driver's side port and here are the measurement's,51" wide x 34" depth x 29" height. The floor has a step up at 20" and goes up 4",then back the 14". Because of the step up and wheel well,I'd have to curve the port to get a tunning of around 32 hz,or is there another way of doing it,but still having a driver's side port? My goal is tunning around 32 hz but can someone help me with the correct design,thank's.
Old 08-20-2015, 04:54 PM
mega fatty
0/11 sssss6008
build the port as long as you can before the bump will effect the port.
then if you want lower tuning build a block to just plug some of the port.
07 mazdaspeed3
rd d9 @ .5ohm
Old 08-20-2015, 05:22 PM
0/11 ssssss316
Ok,so keep the port straight without any bends?
Old 08-20-2015, 06:20 PM
mega fatty
0/11 sssss6008
Yeah
I assume you want driver side port for the meter?
Then the bump up in tuning will also help a lot
Then plug for daily or demos
If you even need it
Old 08-21-2015, 10:38 AM
0/11 ssssss316
yes and to play low,hopefully do some hair trick's. Or should I change the port location?
Old 08-21-2015, 11:03 AM
mega fatty
0/11 sssss6008
I would keep it
You will most likely be fine with the higher tuning
Walls kill lows
In a good way
Old 08-21-2015, 01:06 PM
SWIFT's Avatar
0/11 ssssss656
Surely you dont have 29in height front to back 34in deep, take away the 4in bump up. You have 25in height going all the way back 34inches? It must slope down going back surely being a hatch? Surely thats just baffle measurements.
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
Old 08-21-2015, 05:07 PM
0/11 ssssss316
Yes,you're correct. So,with those measurement's and I do a 8" wide port x 12" long,would that work? Would it still play low?
Old 08-21-2015, 05:11 PM
mega fatty
0/11 sssss6008
what is your internal volume?
07 mazdaspeed3
rd d9 @ .5ohm
Old 08-21-2015, 07:54 PM
mega fatty
0/11 sssss6008
just rough guess you should be tuned around 35 with that port
should be loud
07 mazdaspeed3
rd d9 @ .5ohm
Hatchback guys: To wall or not to wall; that is the question Synestersnake31 General Car Audio Discussion & Questions 36 03-05-2014 02:09 AM
4th order wall or flat wall Dirtbikerrob Enclosure Discussion & Design Construction Help 9 03-05-2013 09:25 PM
wall or no wall, scion xb, Obsidian audio 18's 98Expo Enclosure Discussion & Design Construction Help 20 06-07-2012 10:48 AM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 08:37 PM
wall guys help please. single psi 15 wall or not? blk1990gt Enclosure Discussion & Design Construction Help 1 04-18-2012 09:39 PM
