Sealing off the trunk? - Car Audio Classifieds!
Old 10-15-2008, 10:04 PM
0/11 ssssss414
Default Sealing off the trunk?
I am considering throwing some 15's or 18's in my trunk, and i was wondering how would i go about sealing it off? Any input is greatly appreciated.
Old 10-15-2008, 10:06 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Are you talking about a trunk wall?
Or doing them IB?
Or
What exactly are you trying to seal off?
/ CAAA Member #2 /
Old 10-15-2008, 10:10 PM
0/11 ssssss414
Im thinking IB. My trunk of my car, i want to put 2 15's or 18's in it.
Old 10-15-2008, 10:11 PM
0/11 sssss1123
one way would be to go through the rear deck, and seal it off from there.
Old 10-15-2008, 10:12 PM
0/11 ssssss414
I just want to have them IB. And keep everything how it is. I do not want to cut up my rear deck or anything.
Old 10-15-2008, 10:18 PM
SPY SPY is offline
0/11 ssss10192
Mount a baffle where the seats fold down then fill in all the gaps with expanding foam and cover the entire area with sound deadener, do the same for the rear deck also.
/ CAAA Member #2 /
Old 10-15-2008, 10:21 PM
0/11 ssssss414
Okay, that was my next question. The rear deck. How would i go about getting that covered? Just put mdf over it and stuff to make it so no air can get to it? I dont have to have a back on the "wall" the trunk is the backside of the "wall"?
Old 10-15-2008, 10:32 PM
SPY SPY is offline
0/11 ssss10192
Correct.
It's not a true IB setup since you can calculate the airspace in your trunk though. It's refered to a TBB setup.
You just need to make sure you completly seal off the trunk from the cabin of your car.
/ CAAA Member #2 /
Old 10-15-2008, 10:35 PM
0/11 ssssss414
Okay, so that rear deck is a must. So it shouldnt be too hard to seal it off, just the "wall" and the rear deck and im set? Easier said then done though.
Old 10-15-2008, 10:39 PM
SPY SPY is offline
0/11 ssss10192
Much easier said than done.
I was planning a build like this myself but I decided I didn't want to permanently disfigure my trunk to do it.
/ CAAA Member #2 /
Patrick's CACO amp rack and trunk panel ideas Patrick Simmons Enclosure Discussion & Design Construction Help 31 01-18-2009 05:19 PM
USACi Sanctioned Event - In The Trunk ~ BEAUMONT TX ~ 10-04-2008 Patrick Simmons Car Show Feeds 0 09-29-2008 02:05 AM
