Can I fire port through speaker grill? - Car Audio Classifieds!
Old 08-21-2015, 08:26 PM
0/11 ssssss427
Default Can I fire port through speaker grill?
Title says it. Want to do a 4th in the trunk, fire through the speaker grills and seal off from the trunk. I know it will be some restriction, but enough to make a difference?
Here's a picture of the grill:
Build log:
High resolution photos:
Old 08-21-2015, 08:31 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
thats a good question, i would think it would restrict it a bit but how much i dont know
Old 08-21-2015, 08:50 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Looks like a Malibu?
Old 08-21-2015, 08:55 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
May lower tuning and velocity slightly.
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 08-21-2015, 09:06 PM
You guys are overthinking it.
It will be fine, the biggest issue will be rattling can be caused.
If anything a screen will lesson turbulence and straighten out back spins.
Old 08-21-2015, 09:13 PM
Partially Unwound
0/11 sssss2697
The rattling is what I was getting at with asking if it was a Malibu (or other GM clone.) I cut out my back deck because of this annoying noise, plus those grills will need to be attached, they popped up all the time from vibration.
Old 08-21-2015, 09:22 PM
0/11 ssssss427
Good to hear. I'll tune maybe 2Hz higher or so.
It's an Impala. I'll be doing whatever I need to do to take care of rattles/loose parts.
Build log:
Old 08-21-2015, 09:27 PM
Partially Unwound
0/11 sssss2697
You could always cut the center out and use mesh or grill cloth spray painted to match the interior if it becomes an issue.
Spray paint works on dingy floor mats and carpets too!
Old 08-21-2015, 09:52 PM
cshaw's Avatar
0/11 ssssss101
even if you had a high port velocity, i would think you would hear port chuffing before you would hear any added port noise that cover might add.
Old 08-22-2015, 10:45 AM
0/11 ssssss427
Yeah, thought of that, but trying not to do that. I'm going to butt the end of the port up against the grill with a strip of weatherstrip, it shouldn't move too much unless it starts to pop out.
Build log:
speaker grill & power wire jaymoung Wanting to Buy (WTB) 2 11-04-2014 11:36 PM
custom speaker grill blkmrideon22s General Car Audio Discussion & Questions 10 07-03-2014 01:13 PM
Plastic Door Grill Affecting Speaker Performance? Burkem_10 Sound Quality Area 7 07-04-2013 03:01 PM
Side fire port vs front fire port? Jfool289 Enclosure Discussion & Design Construction Help 0 02-22-2013 09:52 PM
amp, headunit, speaker grill DLP customs Wanting to Buy (WTB) 4 03-29-2011 11:46 AM
