Box for 14 silverado double cab under rear seats. - Car Audio Classifieds!
Old 08-23-2015, 11:19 AM
0/11 sssssss88
Default Box for 14 silverado double cab under rear seats.
I have a 10"sub with a muting depth of 6.5".it's a 10" fi...I would love to have it under my rear seats or as close as possible to it being under my rear seats.my problem is the mounting depth seems to be about an 1" too much for it to fit directly under my seat.I would like help on a ported box too.but I cannot sacrifice my rear seats in order to fit a box.any help plz?
Old 08-24-2015, 08:19 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
i'm not sure about the double cabs but on the crew cabs there is empty space in the bottom of the seats where you could build a extension on the box.
In my box for my crew cab we cut out a whole just big enough for the magnet to slide in, then cut out a ring that was 2" bigger than the hole and a 1/2" mdf spacer to sit it out a little farther.
You'll be hard pressed to accommodate 6.5" of depth though. my sd3's are 4.5" depth and I might have been able to get another 1/2" before it would have started keeping the seat from going all the way down.
Maybe ditching the rear seats PapaGeno21 General Car Audio Discussion & Questions 0 05-24-2013 11:23 PM
Box request for JPence23 (2012 Crew Cab Silverado) JPence23 Box Requests 0 05-06-2013 10:58 PM
2012 Silverado Crew Cab Box Ikyo75 Enclosure Discussion & Design Construction Help 10 04-01-2013 01:29 PM
94 silverado ext cab rear seat d2freak82 General Car Audio Discussion & Questions 0 11-20-2011 08:30 PM
Need box idea(s) for 2 old-school 18"XXX in a '10 Tundra Double Cab hollatchaboy Enclosure Discussion & Design Construction Help 6 04-19-2010 08:19 PM
