Need help with my box - Car Audio Classifieds!
Old 10-19-2009, 03:47 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Default Need help with my box
This is my current enclosure. At near full power it bottoms out. Before anyone says something, everything is tuned correctly so don't ask about amp settings. I figure that maybe the sub is loading into the port to some extent and that is the reason for bottoming out.
Should I get another enclosure made or should I just switch setups?
I have space for 2 boxes, slightly different in size but different in styles as well.
1 - 32.5w x 13.5h x 26d...this way I can do 1 or 2 12's facing the rear.
2 - 32.5w x 13.5h x 28d...this way the sub(s) would have to be sub up.
Old 10-19-2009, 03:56 PM
0/11 ssss31258
I'm going to say it anyway.
Do you have your subsonic filter turned on and set to 30hz?
{Sorry I haven't replied to your last PM}
Old 10-19-2009, 03:57 PM
0/11 sssss5305
that's a lot of power for that sub. at what freq does it bottom out at?
Old 10-19-2009, 04:01 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Sonic, it's set at about 30, maybe 28 or so. Strass, any lol. Just close to full power it does. I am honestly thinking it fires into the port.
Old 10-19-2009, 04:03 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
A single 12 setup, I could have a slot ported enclosure where it might be slightly easier to fix that problem. But I like to play close to full tilt the entire time I'm in the vehicle...and I'm a delivery driver lol so I figured 2 12's would help ease the tension on each woofer.
Old 10-19-2009, 04:08 PM
0/11 sssss5305
I'm thinking too much power for daily coupled with a single 12" set up, so you're playing full tilt the entire time. Try to go with 2 subs to increase SPL and spread the power out and you might be happier...
Old 10-19-2009, 04:12 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Absolutely. I wanna do 2 Omega's on my amp. Later down the line, grab a 4500 from jacob or something in that range. Should slap "kind of" nicely lol
Old 10-19-2009, 04:20 PM
0/11 sssss5305
still won't be loud enough and you'll be playing full tilt the entire time. Some of the younger DOA guys are that way.
Why not another NS?
Old 10-19-2009, 04:23 PM
0/11 ssss31258
I tell ya if I had some 12s we wouldn't be discussing this.. cuz I woulda traded you already.
back to the topic though... you don't have a bass boots or loudness turnned on on your deck do you? if so, turn it/them off and see if it still bottoms out.
Old 10-19-2009, 04:38 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Bass boost has always been off and loudness is off on the deck. I was thinking about another NS from woofercooker and still can...but he said go about 4.25 for the lows each and it looks like I don;t have quite that amount. on the RE calculator, those measurements (26d) gives me 3.99 after port so about 3.7 after subs and tuned to 30 hz.
