Quick box design check/help/suggestions. - Car Audio Classifieds!
Old 09-03-2015, 06:00 PM
nkrell11's Avatar
0/11 sssss1420
Default Quick box design check/help/suggestions.
Hey guys was just hoping to get a little input on my design for my 2 Fi N3 15's wondering if there is anything I should change or if this looks right. Looks good to me just double checking before building it. It will be going in my 2004 Grand Prix on my flatline 7K at 1 ohm. Will be building in the trunk, had discussed subs up ported to the side with Todd but to get the volume necessary etc I'd have no room for mounting my amp and such
I asked Jeff for a little help as he ran and built the sub, this is what he recommended.7.35 - 7.75 cubes for the pair after displacements
29-35 tuning. I tuned to 31. they like a little extra port, 14 sq inch per cube for square, 12 per for round. Overall the volume is a little smaller and the port area per foot is down an inch but I'd really prefer not to give up more space could go a tad wider but then the opening to the cabin would be more blocked off.
Anyways on to the pictures, considered putting a threaded rod from side to side for extra bracing. Will probably trim out a little around the pieces around the port the extra thickness is to flare as I have a 5/8's round over.
Any help is much appreciated thanks guys.
Jeep Build Log:
Daily (Rebuild Pending)
Old 09-03-2015, 07:50 PM
nkrell11's Avatar
0/11 sssss1420
If I make it a half inch wider my volume will be closer to what Jeff recomended but I will probably do that.
Jeep Build Log:
Old 09-04-2015, 07:27 PM
nkrell11's Avatar
0/11 sssss1420
No one has an opinion?
Jeep Build Log:
check this box real quick!!!! badmofo529 Enclosure Discussion & Design Construction Help 16 09-04-2013 09:10 PM
Check my box design. Matt3824 General Car Audio Discussion & Questions 14 10-10-2012 12:56 PM
Double Check my box design 2 XL M2 jfoodstamp (DC) 5 09-27-2012 04:02 PM
check my box/any suggestions? 1-12-t1 General Car Audio Discussion & Questions 3 12-10-2010 07:30 PM
Check this DD designed box design? da box king Enclosure Discussion & Design Construction Help 8 08-16-2009 07:54 PM
