CRV 4th order - Car Audio Classifieds!
Old 09-05-2015, 10:19 PM
KickinBlazer's Avatar
0/11 sssss1122
Default CRV 4th order
ok guys i have a good amount of room but im wanting a numbers vehicle im thinking a large ratio 4th order 4:1+ ...goal is 150+ no deadening under 1krms with no mods except electrical....i have max measurments at 33x33x33....for a slide in box i was thinking 3.15 on sealed side and the rest on ported side tuned to 46hz or so...maybe higher....any thoughts?
if its to loud your to old!
Old 09-05-2015, 10:30 PM
Turn it up's Avatar
0/11 sssss1933
that sounds like a good start.i say do port forward sealed like a "trunk wall"
Old 09-05-2015, 10:32 PM
0/11 sssss1122
yes the box will have port forward and sub facing down....im still wanting to listen to it daily and must at least sound good on music.....the higher ratio will narrow the bandwidth and increase output?
Old 09-07-2015, 06:41 PM
spl_robb's Avatar
0/11 ssssss571
What size sub or subs? interested on the results.
(2)10" Mids (2) HornsD290Py S (2)TW 700Ti all PRV
2 x 18" DSS SAVAGES/2 x SOUNDIGITAL 12K @1 ohm
4 BANKS OF SCAPS/ shca ofc cable wire 4 runs.
Old 09-07-2015, 06:47 PM
0/11 sssss1122
A single psi platform 1 18 or some other small motor 18 one that likes sealed
Old 07-05-2016, 02:57 PM
spl_robb's Avatar
0/11 ssssss571
back from dead, how did it work man?
4th Order vs. 6th Order? younggunzbass01 Enclosure Discussion & Design Construction Help 18 05-24-2011 04:34 PM
