Any simple way to tell where a box is tuned? - Car Audio Classifieds!
Old 09-13-2015, 10:33 PM
0/11 sssssss85
Default Any simple way to tell where a box is tuned?
How do you tell where a box is tuned? I figure I can run test tones, should I be looking for where I can feel the most air coming out of the port, or is there a better way?
Old 09-13-2015, 10:36 PM
massivespl's Avatar
0/11 sssss8409
If u have a computer download Torres box calc and type in all ur specs. It's pretty darn close.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-13-2015, 11:05 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
You can eyeball it by watching the sub. It will move the least at tuning.
Or clamp
Or WooferTester
Or break out the tape measure and do the math
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 09-13-2015, 11:06 PM
0/11 sssssss85
I used Winisd, but my slot port has a 90 turn at the end, and I wanted to see what that did to the actual tuning.
Old 09-14-2015, 02:52 PM
0/11 sssssss85
Or clamp
Or WooferTester
Math was done by WinISD.
Not sure what a WooferTester or clamp is (other than the kind I used to build the box).
I could definitely eyeball the cone movement. Anyone know where to find some 25-35Hz individual test tones?
Old 09-14-2015, 03:24 PM
Beatdown337's Avatar
0/11 sssss1535
If you have all the dimensions ill do the math for ya bro. i can help break it down for you so that in the future you can have that as another tool in your belt. win isd is a great program, i use it as well
Old 09-14-2015, 03:27 PM
HiloDB1's Avatar
0/11 sssss3158
To do this method one needs.....
1) a power amp, or receiver
2) a DMM (preferably a TrueRMS unit)
3) a method of generating low frequency sine waves (tone generators are easiest)
4) a approx 100watt, 20 ohm power resistor (there's latitude with this value, so just get close).
To test the tuning frequency of a ported sub:
Wire the resistor in series with the (+) lead going from the amp to the (+) woofer input terminal. Wire the (-) lead normally from the amp to the (-) speaker terminal.
At low volume send 50Hz sine wave into the speaker.
Set the DMM to "AC" and measure the voltage across the +/- terminals of the woofer.
Set the output from the amp so the multi-meter reads between 1&2 volts.
Now lower the frequency in steps 5Hz at a time. Each time write down the voltage reading from the meter.
As you go down in frequency there will be a point where the voltage bottoms, then starts back up again with the next lower frequency. The lowest meter reading is the port tuning frequency.
For example:
50Hz-1.2V
45Hz 1.3V
40HZ 1.2V
35Hz-1.1V
30Hz-1.0V
25Hz-.75V
20Hz-.5V
15Hz-.75V
10Hz-1.1V
In this example the port tuning is 20Hz. That's where the meter reading shows the lowest voltage.
Obviously you can use steps smaller than 5Hz for greater accuracy.
The Following User Says Thank You to HiloDB1 For This Useful Post:
theaestheticgreek (10-01-2015)
Old 09-14-2015, 03:40 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
^thats how i tune crossovers^
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 09-14-2015, 05:02 PM
0/11 ssssss285
I'm not sure how voltage would change, unless the back EMF from the coil moving is affecting voltage which makes sense, but you will see impedance spike above and below system tuning. Or you could try a cooler method.
https://youtu.be/QhIoX97B5XI
Old 09-14-2015, 05:29 PM
0/11 sssss1070
if i were to do this for setting a HPF on an amp how much voltage drop should i be looking for here? i guess i could get all technical with it depending on slope and whatnot but is there a general idea?
Simple Box Bologna Enclosure Discussion & Design Construction Help 24 06-30-2013 02:26 PM
just a simple box question michaellane General Car Audio Discussion & Questions 1 02-23-2012 07:03 PM
simple box design help Dunbar91 Enclosure Discussion & Design Construction Help 5 08-31-2011 11:57 PM
Need a simple box design... Dunbar91 General Car Audio Discussion & Questions 0 05-17-2011 02:56 PM
simple box design korey_hofer Enclosure Discussion & Design Construction Help 11 10-19-2010 11:06 PM
