4th order help - Car Audio Classifieds!
Old 10-25-2009, 12:12 PM
0/11 ssssss119
Default 4th order help
thinking of doing a build with 2 10's or 4 8's in a 4th order. the max external dimentions are 14.5hX34.5wX18d. not sure if the 4 8's will work but it would be nice if they did. I would like to try and get the tuneing around 32-35hz. If you have suggestions on this and also some subs that will fit the bill go ahead and post it. This is just a thought right now not even sure if it'll work since i've never done a BP box.
thanks for any help you guys can give
SAZ-3500D Pre-Order v.2 sundownz (Sundown Audio) 29 08-20-2009 08:57 AM
In order fatpat1080 Uncensored Off Topic 26 07-01-2009 11:17 AM
did I order the right ohm woofers? vicon4z General Car Audio Discussion & Questions 16 06-24-2009 12:32 AM
6th order ... look good? sholiz Enclosure Discussion & Design Construction Help 3 06-16-2009 12:42 PM
