4th order question - Car Audio Classifieds!
Old 10-01-2015, 07:26 PM
0/11 sssss1090
Default 4th order question
From my understanding, the bigger the sealed section on a 4th order box the lower hz the box will play. For instance a 2:1 tuned to 50hz ratio box will play lower than a 4:1 ratio tuned to 50hz box. Correct?
Old 10-01-2015, 07:36 PM
0/11 sssss1117
it still will play just as low but the ported side will have a higher peak at tuning frequency and a steeper roll off with a larger ratio. You have to think of it like a ordinary sealed box but the ported section will have a different peak
Old 10-09-2015, 03:28 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Bigger sealed section will play lower typically. Smaller ported section is wider bandwidth, typically.
The Following User Says Thank You to jt_buck For This Useful Post:
bassman_soundking (10-09-2015)
4th order port question Ryanfusion General Car Audio Discussion & Questions 20 08-26-2013 08:48 PM
Port for 4th order question Fishy General Car Audio Discussion & Questions 7 02-02-2013 03:30 PM
4th order tuning question treylittlefield Enclosure Discussion & Design Construction Help 5 08-07-2011 01:07 PM
Another 4th order question.. tez4life General Car Audio Discussion & Questions 1 03-17-2011 05:21 PM
