Ok guys planning my new box need a bit of help with a few things - Car Audio Classifieds!
Old 10-25-2009, 08:58 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
Default Ok guys planning my new box need a bit of help with a few things
Well I am in the midst of doing another system. The max dimensions for the box is 33 wide14" high and 24" deep. Going in a 97 acura cl. Now I always use the re calc (i know not the greatest but **** if the others dont confuse the hell outta me). So this is gonna be sub up port back, 4 cubes with tuning around 36.8 (before sub ) 5.5" port and yea gonna double baffle it(also bracing with all thread). Max height is 18.5-19 but figured leave a few inches for excursion. I'm leaning towards all sundown gear saz3000d and a 18 or 15 nightshade. I know 4 cubes isint much for a 18 but I've been wantin one bad, still decidin may go with a 15 never know. I've done 2 12's and a single 15 and I just want more. 15 was a dd 9515 with dirty power, and the 12's we're dc 3's with dirty power. Maybe a single 15 with clean 3k would be it?
Sorry for all the info but gives you a idea what im workin with. So my ?'s are it gives me 26.75 port length and 68.75 inches of port is this about right with length
''(i know 16" per cube is desired so im good there). Also where it says square port length it usually has 8 as standard but does it make much a diff if you dont have it at all?
Old 10-25-2009, 09:01 PM
Bender-Offender's Avatar
0/11 ssssss142
i would get a beast of a 15. That is no where near enough air for a 18.
Old 10-25-2009, 09:19 PM
biscuit's Avatar
0/11 ssssss555
theres plenty of room for the right 18"... i ran 2 re mt 18s chsmbered with 3.8 cubes per tuned @36hz with 3 4"aeros per and 3k per in my suburban behind the 3rd row seat and burped out 151db all day and it played real musical... as long as you got the power and the sub has the bl youll be good...also did 1 18" mt in my boys 300z hatch 4.4 before disp. dont remember the net... doin a 149.5 street beat to mariah careys breakdown... with 1800w alaso used 4" aeros... ive got other instances but i dont think i should carry on.... just say f it n go big!
edit: get the equpiment... squeeze as much box as you can, then worry about tuning...
Old 10-25-2009, 09:34 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
lol yea i really want to work with a 18 as I never have. I figured a nightshade 18 would get nasty with a 3000d. The box i have figured up is slot port only worked with aeros once(not good with them).
Old 10-25-2009, 09:39 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
I've never heard such stupidity.
A smaller sub in the correct enclosure will not only get louder but it will sound better than a larger sub in too small of an enclosure.
/ CAAA Member #2 /
Old 10-25-2009, 09:42 PM
98AckCL23's Avatar
0/11 sssss9929
From what I've seen, Nightshades like smaller boxes, so you could probably get an 18 in there... Just a thought, but it'd be sick to see an 18 in the trunk of a CL...
Maybe 2 very beefy 12s would work on a 3k at .5? Just another thought...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 10-25-2009, 09:51 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
Yea well so far im leanin to 2 c&d tech batts (why cuz they seem good and are cheap 70 each picked up) I have a ho alt. Maybe the sundown 3k and ns. Damnit i cant decide the 18 or 15 guess a few days of pondering will help as i dont get my moneys till wed when I sell my bike. I just want to get nasty nasty loud. Hey Matt im also thinkin bout taking the metal brace off the seat but does that affect anything as I want to keep my seat there (for the car seat lol) and it helps get way louder right? So guys the main ? the L wall how bout it is it ok to just have it at 0. And man I'm have more views and responses here than at ca.com
Old 10-25-2009, 09:58 PM
98AckCL23's Avatar
0/11 sssss9929
I wouldn't go with the C&D's. There's a couple of people that've had some problems running them with larger audio systems. Just a heads up. There've been a couple threads in the general discussion about batts lately, so maybe check on those...
As for that metal brace, I haven't noticed any differences in handling or anything like that. As for getting louder, I'm not 100% positive, but I would assume that it has significantly helped. It doesn't effect anything with the backseat, unless your box sits as far forward as mine does, and then you'll have to cut 2 little round pieces of steel that slide down into the rear deck to hold the rear seat in place. There are 2 more like supports on the sides of the seat, and 2 bolts in the bottom middle that hold it in, so I would assume there's no problems holding the seat rearward...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 10-25-2009, 10:03 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
Really probs with them. I only read good things. And I figured for 140 or less for two of them if they lasted a year or so I'd be happy. Also thought of spv70's . I'm not wantin to break the bank with this build as the amp alone is gonna run 550ish, tryin to stay below 1k. Well I may leave the support in them as maybe it would help in case of a crash god forbid.
Old 10-25-2009, 11:00 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
And another thing im looking at doing sub up port back I've done both back before and want to try something diff, maybe it would give me the output im looking for. Oh and im gonna stick with 1 ohm not lower lol. So lets say I go with a 15" ns would it handle 3k daily? Or should I maybe go with a sundown saz2000d? With the 5.5" port it should slam but man i'd love to have a wider port,but the tuning goes into the 40's and then Ialso loose cubes. Sorry for all the ?'s im just havin a hard time decidin
Planning stage for the 1st Annual CarAudioClassifieds Car Show & Sound Comp Patrick Simmons Competition Corner 142 07-03-2009 03:00 PM
Planning out my equipment! Input wanted. Andrew General Car Audio Discussion & Questions 26 06-09-2009 05:21 PM
planning blowthrough, need some help mcdstvn General Car Audio Discussion & Questions 21 02-25-2009 09:00 PM
So heres what im planning - Opinions Please worstenemy453 General Car Audio Discussion & Questions 63 10-10-2008 12:04 PM
