How hard is it to build a box? - Car Audio Classifieds!
Old 10-04-2015, 12:25 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default How hard is it to build a box?
If you only have a jigsaw and skilsaw?
FWIW, we also have a cordless dewault 18v saw.
team graham
Old 10-04-2015, 01:13 AM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
done it many times. im assuming youre just asking about the basics to dice it all up, no?
as long as your lines are straight, angles true, and your circles round, you should be fine.
toss the cordless saw for that job unless youre cutting notches for some odd reason,.. they dont really last long cutting 3/4" of anything
who wants a nudel ride?
Old 10-04-2015, 02:57 AM
0/11 sssss1085
Feedback Score: 23 reviews
Clamp a long straight edge or anything straight to the wood you're about to cut to use as a saw guide. Using that method, you can make just as good of a cut as a table saw.
Old 10-04-2015, 03:37 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
I only use a circular saw for boxes. Any table saw under a grand is trash IMO. Way better cuts with a clamp guide and circular saw. Predrill. Use Titebond II. And measure twice cut once.
Current Build:
#60sHereIcome
Old 10-04-2015, 03:58 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Had to look up what a circular saw was. Basically a skilsaw, lol.
I'm good with them.
The dewalt 18v we have works really good, despite it being mostly plastic.
team graham
Old 10-04-2015, 04:05 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Also, which sundown sub should I use for the box design?
The NSv3, x12 and zv3 all need 2.5 cubes...
Treo has nothing on the website other than listing that it needs 2.25 net.
team graham
Old 10-04-2015, 04:26 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Ok so apparently the only ones that give the layout are the Z and X series...
Not sure what the extra port length inside would do
Which of these should I try to copy?
Both claim 32hz, 40^2 of port....unless I'm reading that wrong
Z v.4 Rev.2 on the left.
team graham
Old 10-04-2015, 06:31 AM
massivespl's Avatar
0/11 sssss8409
What sub are u building a box for? And how much power do u have?
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-04-2015, 06:58 AM
only126db's Avatar
The One U Love 2 Hate
0/11 sssss2945
Worm Drive Skilsaw, Bosch Jigsaw, PorterCable Router, Dewalt Cordless (tools of choice)
I have built many many many boxes and I have yet to clamp a straight edge to wood, have a steady hand and follow the line, you should be golden.
Without a large table saw you will need saw horses of some sort when ripping sheet material.
Old 10-04-2015, 07:00 AM
72impala's Avatar
0/11 sssss1706
Feedback Score: 68 reviews
Who told you to use a sundown subs box recommendation for a treo sub? What sub? I know where to find all treo T/S parameters. Maybe ask for those first.
2003 6.8L V10 Excursion Limited
2015 MECA STREET 5 WORLD CHAMP
Box request for trunk hit hard like kimbo trunk hit hard like kimbo Box Requests 1 03-30-2013 08:21 PM
my hard working box JAYARE2007MAG (Sundown Audio) 14 05-26-2012 12:32 AM
Box request for trunk hit hard like kimbo trunk hit hard like kimbo Box Requests 0 02-16-2012 11:01 PM
can i build sub box with hard wood instead of mdf? armyranger3858 Enclosure Discussion & Design Construction Help 0 02-03-2011 09:26 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 01:43 AM
