Easy box for treo ssx 28hz? - Car Audio Classifieds!
Old 10-19-2015, 10:07 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default Easy box for treo ssx 28hz?
Edit: 12" dual 2
Need some easy ass design I can do myself (first attempt)
18x18x whatever
Box must sit on drivers side with long end going towards the front cause I sleep on the other side.
Sub up port side or sub up/port up with port at rear??
Flush mount cool but not a big deal
Free head unit for good design?
Right now it's in a 1.75 32hz with sub inverted.
Gain at half on crescendo symphony 1500 and it hits 13.5 full tilt. I'm happy but I know the box will add a lot..
team graham
Old 10-19-2015, 11:44 PM
0/11 sssss3526
Sub up, port back? If you sleep in there do you want it running down one side only?
Old 10-19-2015, 11:52 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Port back = more punchy? I want long slow boomy bass.
Yeah that measurement is enough for me to sleep on the other side of the box
team graham
Old 10-19-2015, 11:56 PM
0/11 sssss3526
So 18 tall and 18 width and whatever length?..
Port orientation varies vehicle to vehicle; just curious if it was an option. Populating your thread with useful info for designers... If no one chimes in I'll look into it
Old 10-20-2015, 11:02 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Yeah that will still be lower than window line and give me enough room to put a patio chair cushion next to it. I have over 5' length to use so that's not an issue.
Cda-9883 or deh-3300ub up for graabs
team graham
Old 10-20-2015, 11:17 AM
0/11 sssss3526
Do you want loud, linear, low end etc? What do you listen to?
Old 10-20-2015, 11:27 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Peaks at 41 now
I like 28-32 best. I want the peak lower
I want stability. Don't want to unload the sub easily. Not exactly sure what your question means.
Decaf 24/7 baby
team graham
Old 10-20-2015, 11:39 AM
massivespl's Avatar
0/11 sssss8409
Someone build this man a 6th order with 18x18x60 to work with
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-20-2015, 12:01 PM
Super Moderators
0/11 sssss9623
sleeping with your subs ?
Old 10-20-2015, 01:36 PM
0/11 sssss3526
Ya for what its worth, a buddy was doing like [email protected] on 2 ssx12 in a trunk 6th order. Lot of power behind it, but it crushed basically 25-40hz
treo ssx 12 box dickdawg Enclosure Discussion & Design Construction Help 2 07-24-2012 01:51 AM
1 Treo 2k amp, 1 Treo SSX 18, 6cube box mikeyg402 Car Audio Packages 5 08-06-2010 12:08 PM
[WTB] TREO SSX 12's and TREO AMP godsgift101 Wanting to Buy (WTB) 1 04-29-2010 09:20 PM
treo ssx 12 aeroport box Treoslapper Enclosure Discussion & Design Construction Help 1 02-23-2010 11:40 PM
treo ssx box neilholland28 Enclosure Discussion & Design Construction Help 4 10-29-2009 08:50 AM
