Driver to Port relationship - Car Audio Classifieds!
Old 10-28-2009, 01:55 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Default Driver to Port relationship
I remember there being a discussion about this at one point somewhere but I can't find it.
What effect does the placement of the drive in the box in relation to the port wall have on the output/efficiency if there is any difference?
The box I'm about to build will be long and skinny so I need to know if I need to put the sub as close to the port as I can get it, somewhere in the middle, or all the way on the opposite end.
Team CACO Team SHOK
Supporting Member
Old 10-28-2009, 01:57 PM
jbizzle's Avatar
0/11 sssss4346
Feedback Score: 26 reviews
I would like to know this as well, but IIRC you want it farthest away from the port to "create" pressure.
Correct me if i'm wrong (most likely i'm wrong)
'07 Chevy Trailblazer SS AWD (Garage Queen)
- Alpine 9887
- Eclipse SC8365 3-Way front stage
- Sundown SAX-125.2
'98 Jeep Grand Cherokee (Daily)
- Alpine 9887 (Active)
- Selenium 6" Mids, 4 Crescendo CTS-1 Tweeters
- Sundown SAX-100.4D
- 2 Sundown SA-12s
- Sundown SAZ-1500Dv2
Team Sundown Audio
Old 10-28-2009, 02:06 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
I would just always try to keep the sub mounted as far away from the interior port opening as possible...as far as exterior positioning of the sub compared to the port it would probably have effects more according to where the enclosure itself is positioned compared to the meter/your ears rather than where the sub/port are in relation to eachother
You would want to keep the sub(s) as far away from the interior port opening because you dont want the sub to not 'use' all of the airspace intended for it and just basically fire directly out of the port (unloading)
Louder. Lower.
Team Tupperware
Old 10-28-2009, 02:07 PM
0/11 ssssss888
This is what ive heard. LousianaCRX had a thread about his 4 10's build log a while ago and there was discussion on this as well.
Old 10-28-2009, 02:09 PM
Slam's Avatar
I slam
0/11 sssss3772
wavelength is a factor here
Old 10-28-2009, 02:11 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Hmm.
I will be putting the Sundown X-12 in my moms Yukon in a standard slot port box ~2.25 cubes and I'm thinking about tuning to 32hz.
But I was talkin to Bumpin Buick and he told me to run it along the driver side wall with the sub and port both up and mentioned some distances from stuff, but didn't say where to put the sub in the box in relation to the port. lol
And once I figure this out I will need a box design so you guys can help me out with that too.
Team CACO Team SHOK
Supporting Member
Slam's Avatar
I slam
0/11 sssss3772
If in a square room is a sub in the opposite corner louder then the others?
Old 10-28-2009, 02:13 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
That is what I've heard, but my room isn't perfectly square and I haven't tried it.
But in a house when firing the sub into a corner I always has the loudest/lowest output from the sub.
Team CACO Team SHOK
Supporting Member
Old 10-28-2009, 02:14 PM
0/11 sssss8346
Originally Posted by 92K1500 View Post
Hmm.
Yea, he mentioned the positioning of everything compared to the vehicle rather than between the port/sub because the positioning in relation to the environment/your ears/the meter would, imo, matter more than the positioning between the sub/port (as long as the sub is pretty much as far away from the interior port opening as possible, thats one thing I would focus on)
Yep wavelengths pwn
Louder. Lower.
Team Tupperware
Old 10-28-2009, 02:17 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Hmm. I shall put shoes on and go bring the Yucky into the garage and measure my box's max dimms so I can get conformation on where it should be placed and a box design at the same time.
Team CACO Team SHOK
Supporting Member
Port Gamble Car Show 2009 to Benefit Breast Cancer ~ Port Gamble WA ~ 08-29-2009 CACO's Car Show Bot Car Show Feeds 0 08-17-2009 02:00 AM
Need New Driver 4thOrderdesign General Car Audio Discussion & Questions 21 03-25-2009 03:28 PM
What kind of relationship would you rather be in? BarbieBs_Mindbox Powder Room 43 03-08-2009 12:13 AM
