Would this box be a good fit for Sundown Z V.4? - Car Audio Classifieds!
Old 10-25-2015, 02:02 AM
cato3's Avatar
0/11 sssssss68
Default Would this box be a good fit for Sundown Z V.4?
I've been looking everywhere for a big enough box to accommodate my Z V.4 and my small 07 Mustang trunk space. I was thinking this box and I also read adding stuffing to the box makes the sub think it's getting more air or something to that effect, could just all be fake. Any suggestions?
05-15 Ford Mustang - Single 12" Ported Sub Box
Old 10-25-2015, 02:09 AM
KickinBlazer's Avatar
0/11 sssss1122
little small for a zv4 and not a good amount of port area....specs say 19 square inches of port total....sundown recomends 40 square inches
if its to loud your to old!
Old 10-25-2015, 02:28 AM
cato3's Avatar
0/11 sssssss68
Yea I know its smaller than what's recommended but i think that's the biggest I could find that will fit in a Mustang trunk. What I am really iffy about is if it has enough mounting depth. Also what am i going to me sacrificing with this smaller box?
Old 10-25-2015, 03:06 AM
0/11 sssss1122
im more concerned about the port area....with less than half the port area needed its prolly going to sound like poop and the box is 2.1 cube before displacment so after the sub will see 1.87 cube...and that is a bit to small and not to mention the mounting depth is to shallow says on box its 10.5 max...but on a zv4 its 10.8 ...not to mention you need room behind the motor for it to breath so id say 11.5 that box is a nogo
Old 10-25-2015, 07:49 AM
massivespl's Avatar
0/11 sssss8409
I'd put a 10" in that box... Just build the proper box for your woofer and car.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following User Says Thank You to massivespl For This Useful Post:
macsdad (10-25-2015)
Old 10-25-2015, 06:02 PM
cato3's Avatar
0/11 sssssss68
With this small trunk I might just have to get a 10 then
Got a Local Shop that DC would be a good fit for? RustyWCA (DC) 5 07-14-2015 10:54 AM
Help wondering sundown x will fit in 99 Cadillac dirtysouth basshead (Sundown Audio) 4 03-15-2015 01:35 PM
Box won't fit in door or trunk... Build it inside? CousinVin Enclosure Discussion & Design Construction Help 22 08-15-2011 10:31 PM
will sundown audio recones fit dd 1500 series motors rocksolid84 General Car Audio Discussion & Questions 11 03-06-2011 01:01 AM
Think my box will fit in an 00-05 deville? PDAOaudio Enclosure Discussion & Design Construction Help 9 03-05-2011 04:49 PM
