Port Velocity - Car Audio Classifieds!
Old 10-27-2015, 09:59 PM
0/11 ssssss202
Default Port Velocity
Here is the scenario
4 Alpine type r dual 2 on and Opti 6000d
Alpine recommends an f3 of 29hz and an FB of 35hz with port area of 50 in^2 and port volume of .93 ft^3
in order to meet their criteria, this is what I had to do.
Alpine recommends 50 sq^2 but i am at 100 sq^2 inches but not the typical 13-16 sq^2 per cubic foot. If I go bigger port is to long
Port velocity is 27.6 m/s
So in a nut shell if you are putting max power to the subs un-clipped port velocity should be good as long as it is below 34 m/s correct?
I ask because if I add more volume to the box while over powering then I hurt the suspension of the woofer so I need a happy medium so to say.
[IMG][/IMG]
2003 Mercury Mountaineer
My Vids -->
Old 10-27-2015, 10:06 PM
0/11 sssss2011
Feedback Score: 61 reviews
personally i like keeping my PV in the 22-26 range. i think you'll be fine with that PV.
Old 10-27-2015, 10:22 PM
0/11 ssssss202
ok thank you.
Port dimensions at 10"x10"x14"
Alpine also recommends ported box volume of 1 to 1.5 Ft^3 per sub and I am at 2.5ft^3 per sub after displacement. Kind of why I really dont want to go bigger.
My Vids -->
Old 10-27-2015, 11:27 PM
0/11 sssss2011
the reason they recommend such a small enclosure is b/c their subs can only handle their rated RMS in that size enclosure.
Old 10-28-2015, 12:38 AM
You're perfect with that enclosure. Now go build it.
Old 10-28-2015, 01:36 AM
jeffdachef's Avatar
0/11 ssssss440
why not do a 12 inch sonotube instead if you want better port efficiency.
Blaupunkt Velocity VX573 3-way 5x7's 06GTMIKE Component & Coaxial Speakers 2 03-12-2012 11:31 AM
Sub box design air port velocity nwdsk8er Enclosure Discussion & Design Construction Help 4 12-14-2011 02:21 PM
FS: Blaupunkt Velocity VA2100 basserdan 2-Channel Amplifiers 3 03-09-2010 01:06 AM
Blaupunkt Velocity VR250 Biggy CACO Amp Internals 0 02-18-2009 10:25 AM
