Sub positioning - Car Audio Classifieds!
Old 11-04-2015, 03:18 PM
0/11 sssssss85
Default Sub positioning
I have a question about driver positioning. If I have a box directly behind the rear seat, does it matter if the subs fire into the backseat or towards the trunk?
And what if the box is large enough that it fills 95% of the area between the passenger compartment and the trunk, does that change anything?
Old 11-05-2015, 01:38 AM
williamhung's Avatar
0/11 ssssss536
typically firing towards the trunk will have better results, unless you have folding seats and seal the trunk off then firing forward gives more spl.
2 Stereo Integrity HT-15's
1 Stereo Integrity HST-15
Old 11-05-2015, 08:33 AM
mega fatty
0/11 sssss6008
What car and what subs?
Maybe someone on here has a similar setup and will share their results
Old 11-05-2015, 12:03 PM
0/11 sssssss85
Car is a Subaru BRZ. I currently have a pair of Infinity 8's in a ported box, facing forward firing into the back seats. My original plan was to fold the back seat down, and have the subs and port firing directly into the cabin. This sounds good, but with the seat down the seat and/or latching mechanisms rattle and is really annoying. So I end up having the seat up most of the time.
The trunk is not big, and the space between the front of the box and the seat back is kind of wasted. So I had the thought of attaching my amps to the back of the seat (near the trunk floor were the seat back angle provides more room) and having the drivers fire into the trunk. If I were to do this, I would make a new sealed box housing a pair of ID12's. However, the box would have to be as tall and wide as the trunk is, so there would be no "free air" between the back of the seat and the trunk area. I'm not sure if that will cause a problem or not.
Old 11-13-2015, 02:43 PM
0/11 sssssss85
Shameless bump for quasi-accurate interweb responses
Old 11-13-2015, 02:47 PM
jeffdachef's Avatar
0/11 ssssss440
turn it around and face the trunk. 4 inches away from the trunk lid.
Old 11-13-2015, 02:49 PM
jeffdachef's Avatar
0/11 ssssss440
Read this if you have time Positioning a woofer box in a car trunk - bass cancelation - Houston TX
Old 11-14-2015, 02:47 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
Side loading subs, port to the back. my .02 from experience with the BRZ
SHABAM
Old 11-16-2015, 12:56 PM
0/11 sssssss85
Thanks for the responses. I still need to use the trunk, so placement can't be ideal (ie subs facing back, up against lid).
Can you clarify what side loading is? Is it simply putting the drivers closer to the ends of the enclosure (thus closer to the sidewalls of the trunk) rather than putting them in the middle of the enclosure?
Help with positioning Twitney181 General Car Audio Discussion & Questions 4 04-24-2013 12:56 PM
positioning sub's in truck jessdabest77 Enclosure Discussion & Design Construction Help 0 02-02-2013 03:48 PM
Aeroport location / positioning RapidAutoQuotes General Car Audio Discussion & Questions 1 03-19-2011 05:57 PM
positioning steve0o09 General Car Audio Discussion & Questions 12 01-04-2011 05:20 PM
port positioning RidnClean Enclosure Discussion & Design Construction Help 6 01-05-2010 02:46 AM
