4 SA8v2 box - Car Audio Classifieds!
Old 11-09-2015, 02:58 AM
0/11 ssssss403
Default 4 SA8v2 box
looking to see if i have things measured out right and everything looks proper before i commit to building this.
Jensen 7" flipout, infinity reference 6x8 doors,
eclipse ea1412 on the doors, audio control four.1 eq for the door speakers, hc600 kenetik, knu/SHCA 0/1 power/grounds, lanzar opti2000d @ 2ohms on 2 SA8V2 D2's 2cft ported @ 34hz
Rebuilding to run 4 SA8's in a 92 ford ranger soon
Old 11-09-2015, 03:06 AM
KickinBlazer's Avatar
0/11 sssss1122
have to take into account bracing and you have 3 common port walls in that design ....and your port area is on the high side i wouldnt go past 16 square inches of port per cube....15 is a happy medium
if its to loud your to old!
Old 11-09-2015, 10:47 AM
0/11 ssssss403
ok, so with changing that one variable, its where it should be port wise, but tuning drops to 31.6ish. factor in some slight bracing, and i can get the number almost to 33hz.
Old 11-09-2015, 02:02 PM
0/11 ssssss403
I could also double baffle the front of the box to bring the tuning where I need it to be.
Old 11-10-2015, 12:06 AM
0/11 sssss1122
Sa8v2 subs do like the lows....so tuning to 30 to 33 will be fine
Old 11-10-2015, 12:54 AM
0/11 ssssss403
Sounds good bud. Thanks for the responses. Looking to get this built between the holidays in free time.
Old 11-10-2015, 05:44 AM
andy75's Avatar
0/11 ssssss788
I'd definitely do that just for structural integrity.
need help designing box for 2 sa8v2 rmatos2014 Enclosure Discussion & Design Construction Help 4 05-07-2014 12:57 AM
Needing box for single SA8v2 SPLpizzaguy Enclosure Discussion & Design Construction Help 6 03-26-2014 11:06 AM
One sa8v2 on 1k. Box ideas? CousinVin Enclosure Discussion & Design Construction Help 13 03-06-2013 08:52 PM
sa8v2 box design 1loudmonte Enclosure Discussion & Design Construction Help 0 02-20-2012 06:25 PM
SA8v2 box 1loudmonte (Sundown Audio) 0 02-13-2012 02:39 PM
