cubes and port sizing for 18's - Car Audio Classifieds!
Old 11-01-2009, 08:02 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
Default cubes and port sizing for 18's
so im putting 2 custom 18's in my truck. going to run moe spl oriented subs, will run each sub from a 3250v2 at .5ohm. subs will be buitl for 4-5k wrms.
what sizing will i need for 2 18 inch subs? and hwo much port area per cube? is 16 enough per cube or will i need more? before anything is in the box i have about 20 cubes to work with about.
Old 11-02-2009, 10:39 AM
SundownAudioNY's Avatar
Veteran Member
0/11 sssss4646
Feedback Score: 42 reviews
I would suggest around 6ft^3 w/96in^2 of port per driver.
New York State Sales Rep
Team XS Power
PM Me For Termlab Testing
Old 11-02-2009, 09:10 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
think that will be enough space?
Old 11-03-2009, 07:54 AM
Veteran Member
0/11 sssss4646
With 20ft^3, you will be fine (your only looking at ~4ft^3 of sub and port displace)
Team XS Power
Old 11-03-2009, 06:42 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
i can fit a box 48 inches wide. 32 inches deep, 34 inches high. thats the space i have to work with. and if my calculations are correct with the wood thicknedd at 1.5 inches thick that gives me 22^3 before subs port and bracing
Old 11-04-2009, 01:16 PM
Veteran Member
0/11 sssss4646
After wood displace (of 1.5") you are looking at 23.4ft^3. So you have plenty of airspace for what you need.
Team XS Power
Old 11-04-2009, 05:45 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
nice. just gotta design me up a box and im good to go. thanx for the help man.
im thinkin im gona go with a regular slot port. 45 in the back fo the port and i should be good
8 cubes? Team3d Enclosure Discussion & Design Construction Help 6 09-16-2009 07:49 PM
