Sub touching Alum aero port... - Car Audio Classifieds!
Old 11-02-2009, 02:20 PM
0/11 ssssss798
Default Sub touching Alum aero port... UPDATE: INSTALL COMPLETE
FINISHED INSTALL: pics on page 2
Will this effect the performance of the sub at all... like will the magnetic pull towards the alum port have any effect?? bad idea?? shouldnt matter?? or alum isnt magnetic?
The sub drops in, but just BARELY grazes the side of the port right at the end... might be a vibration issue, but im just worried about the magnet issue
sexy 10.5" aero aint it!
Getlikeme:remote start
REFS: (from CA.com)Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle, mlstrass , Mazzasec, SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic meade forum. Team_Psi reconed SSX, Timmy13091 sold Deka Battery,
Old 11-02-2009, 02:21 PM
SPL-Master's Avatar
0/11 ssssss534
alum isnt magnetic but may hit with vibration
Deck: Panasonic CQ-VW100U
Interior speakers: PAP-EMP65s
Amp interior: Kicker kx 650.4
Amp sub: Audiopipe AP-30001D
sub: 2 RE Audio HC 15's
Battery: Stinger SP800 and SP1700
Alternator: Excessive Amperage 250 amp
Box: 8.2 ft^3 at 32hz
Old 11-02-2009, 02:22 PM
No, I'm not dead
0/11 sssss8128
It's aluminum, right? Aluminum is non-magnetic so that's not going to be an issue. The bigger issue will be the port clattering against the sub.
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Maybe wrap the end in duct tape?
/ CAAA Member #2 /
Old 11-02-2009, 02:34 PM
0/11 ssssss798
yea i'll have to do that.... or i'll just get it re-cut if they don't charge me another $25.. (already got 5/8" cut off to get the inner flare in)
Old 11-02-2009, 02:41 PM
RE_Gawker's Avatar
0/11 ssssss682
can you not just grind down the outside edge where it would be touching the sub?
I cant get the picture to load and I can't see much from the thumbnail image so it's hard to tell.
EDIT, nvm, now I see the two other pics...I thought you were talking about mounting the sub next to the port(like sub up port up type of thing)
just about anything you do to prevent it from rubbing can wear through over time, like tape, wouldn't take much rubbing at all to get through the tape and start making it rub again. Depending on how much vibration there is...
sub amp: RD D9 on preorder
Subs: 2 CD omega 18's
HU: 880-prs
highs: Mach 5 mids with peerless tweets
highs amps: sundown 100.4 and 100.2
Old 11-02-2009, 02:42 PM
Inferno333's Avatar
0/11 sssss3845
Feedback Score: 44 reviews
Take foam gasket strips and apply it to the port edge. That will keep it from making noise.
Old 11-02-2009, 06:00 PM
0/11 ssssss798
not sure i'll be able to get the sub past it then
not sure exactly what it is, but foam is usually somewhat thick.
ttt.. anyone else
Old 11-02-2009, 06:02 PM
0/11 ssss31258
notch the flare. you'll be fine.
Old 11-02-2009, 06:04 PM
Me > Lord Van
0/11 sssss2831
Should have flipped that baffle around.
You want the subs as far from the port end as possible.
Aero port displacement Scapelli21 General Car Audio Discussion & Questions 7 09-06-2009 09:21 AM
Aero port tuning tater Enclosure Discussion & Design Construction Help 2 05-26-2009 01:55 AM
aero port on the outside? mrboost General Car Audio Discussion & Questions 4 01-19-2009 10:59 PM
9.5 inch Aero Port Tinted Speaker Accessories & Parts 5 12-11-2008 11:39 PM
