help on spare tire box. - Car Audio Classifieds!
Old 11-05-2009, 07:43 PM
0/11 ssssss614
Default help on spare tire box.
does anyone have pics on how they did a box in there spare tire holder?
im basically looking to find out how to hold the fabric to the baffle.
mojo is the awesome
Old 11-05-2009, 08:02 PM
0/11 ssss31258
Most people making fiberglass spare tire well boxes duct tape the crap out of it, then wax it with car wax, then start laying the material. Once you ad resin the material will kinda stick to the sides. {wax and all} You have to do it in thin layers until some of the resin sets up. Then make your baffle panel and add it while the resin is still somewhat wet. Then after it drys continue adding material and resin until you are happy. {try to get all the material to lay down.. any sticking up will be as sharp and as strong as a fishes fin}
If you have a fabric store near, burlap is cheaper than Fiberglass and just as strong when resined.
[The wax acts as a release agent so the basin is easily removable. if you don't care about that, you can skip it and the duct tape.]
Old 11-05-2009, 08:05 PM
well when I did mine in my mustang I had enough room to use 1/4" plywood and make a box in side the tire space then glass on that to make it stronger
Old 11-05-2009, 08:12 PM
0/11 ssss31258
I made one for a Cavalier which was half in the spare tire well. Basically it was 6" above the well full width of the floor and like 6" in the well. It was for one 15" eclipse. It worked great and would have looked almost like it wasn't there if they hadn't wanted the box covered in Holstein cow print faux fur.
no resin on that one though. it was all 3/4".
Old 11-05-2009, 10:19 PM
0/11 ssssss614
im more wondering when stretching the fleece to get curves how i secure that to the baffle that i would have cut to mount the sub in. say theres a 10" sub so i make a 10 cut out and one glued to that for a flush look. where on that baffle do i secure the fleece to.
mojo is the awesome
Old 11-05-2009, 10:21 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
woud be secured over the edge of the flush mount area and down just like normal
SHABAM
Old 11-05-2009, 10:23 PM
0/11 ssssss614
would i just keep the resin and mat thinner in that area so it doesnt mess up the dimensions or make the flush mount a little wider to accomodate the fiberglass?
mojo is the awesome
Old 11-05-2009, 10:25 PM
DonH's Avatar
0/11 sssss6645
no make the flushmount area wider to accommodate the fleece and resin go 3/16 of an inch larger than planned flushmount cutout diameter.... should be fine
SHABAM
Old 11-05-2009, 10:27 PM
0/11 ssssss614
thanks
mojo is the awesome
22 inch rims and tire package lynch Miscellaneous Stuff For Sale 1 10-06-2009 01:58 PM
Tire/Wheel questions. worstenemy453 Off Topic Chat 2 07-11-2009 11:24 PM
RD audio Alpha 15 + spare upgrade Recone kit MECHMAN 15" Subwoofers 11 06-10-2009 06:17 PM
Sacrifing spare tire for car audio? Patrick Simmons General Car Audio Discussion & Questions 18 11-13-2008 03:12 PM
Remove spare tire? SPY Off Topic Chat 4 08-10-2008 11:39 AM
