Need some help on my tube port box ANY help is great. - Car Audio Classifieds!
Old 12-31-2015, 08:05 PM
0/11 ssssss249
Default Need some help on my tube port box ANY help is great.
Im designing my own box which is a tube port box either going 2.5 or 3 cu ft tuned to 33-34 hz with a 6" port. Since I really only listen to rap, i will be putting a Ab xfl 10 d2 on a execution audio ea.1500.1. I am kinda limited on space since in going in a 1998 trans am. But if you guys have any other ideas please comment. this will be my first tube port box so im really not familiar with them, but i do know they tend to get really loud and low.
Also where i can get a 6" tube port other than precision port.
thanks any ideas help.
Old 12-31-2015, 08:49 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
6" is a bit too much for a 10", and the box is too big for a single 10
Old 12-31-2015, 08:57 PM
andy75's Avatar
0/11 ssssss788
Would be spot on for 2 10's.
Old 12-31-2015, 09:10 PM
0/11 ssssss249
So i should go with 2 cu ft box with a 4" tube port ? same tuning
Old 12-31-2015, 09:34 PM
williamhung's Avatar
0/11 ssssss536
sounds spot on, 1.5-2 is all you need, may want to stick with 1.5 if running that much power...
2 Stereo Integrity HT-15's
1 Stereo Integrity HST-15
Old 12-31-2015, 09:37 PM
0/11 ssssss249
how long should the tube port be ? to be tuned to 33-34 hz. i might go with 1.75 cu ft.
Old 12-31-2015, 09:47 PM
0/11 ssssss536
with 1.5 net after displacement 18" tube gives you a tune of 33.5hz. Should be good to go.
Old 12-31-2015, 09:49 PM
0/11 ssssss536
i just seen you wanted 1.75, at 1.75 net a 15" length tube will give you 33.15hz
0/11 ssssss249
How do you figure that out ? what website do you use? and do you know where i can get a tube port other than presision port of parts-express.
Old 12-31-2015, 09:56 PM
0/11 ssssss536
I use an android app called ultimate car audio app. Its great and is pretty spot on. You can put in all your dimensions and measurements and play around with it till you get what works for you. You can get 4" PVC from home depot and make your own aero's out of it ( tons of YouTube vidoes on it) they run about $10.
Knowledge with sono tube port? 1-12-t1 General Car Audio Discussion & Questions 18 07-23-2015 06:56 PM
Anybody ever do subs up port driver side and great success in a suv??? Mnorwood01 General Car Audio Discussion & Questions 11 11-25-2013 12:09 PM
10 inch quick tube / sino tube klilflipp Wanting to Buy (WTB) 18 09-09-2012 10:58 AM
3"x12" flared port tube 00ram360 Wanting to Buy (WTB) 3 03-23-2011 04:21 PM
