Thoughts on new box? - Car Audio Classifieds!
Old 01-03-2016, 06:06 PM
0/11 ssssss316
Default Thoughts on new box?
I have a two door blazer and I've heard sub's up port back,but i can't squeeze enough airspace for two 15's doing that,so i was thinking sub's and port up with the box all the way to the hatch. Any thought's?
Old 01-03-2016, 06:09 PM
massivespl's Avatar
0/11 sssss8409
Spike131113's DC Soundlab Blazer
This did 150db+ on music on a 3.5k amp
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-03-2016, 06:27 PM
0/11 ssssss316
looks good
Old 01-03-2016, 07:02 PM
KickinBlazer's Avatar
0/11 sssss1122
side firing port....alot of people have had good results doing side firing including me....you can build to the back gate and just fire the port to the side....tune just a little higher than what you want cuz with the port to the side and so far away from the listening position it effectivly lowers the tune 3 or 4 hz....i had a single 18 in the back of a 2 door blazer easy...so if you build it right and use aeroports then you can fit 2 15's in there nicely
if its to loud your to old!
Old 01-03-2016, 07:31 PM
0/11 sssss3526
I'm interested in this as well. I'm doing a build in a 4dr. Do the 2 and 4dr's have the same cargo area? I was planning 4 12s
Old 01-03-2016, 07:39 PM
0/11 sssss1122
no the 4 dr has alot more room in back....4 12's will prolly be a good fit in a 4dr but be very hard to fit in a 2 dr.....but both vehicles share a similar sound and peak close to eachother....my 2 dr peaked at 46hz....but was tuned to 28hz and played anything from 20hz to 55hz with authority ....buddy of mine had a 4 dr peaked 1 hz lower at 45hz and was tuned to 30hz and has pretty much the same bandwidth but both setups wer side ported....you can do rear facing port but enjoy trying to keep the back glass and gate quiet
Old 01-04-2016, 03:13 PM
0/11 ssssss316
I have heard side port but never seen or heard one. Sub's and port up isn't good for these blazers?
Old 01-04-2016, 03:32 PM
0/11 sssss1122
The roofs are weak and tend to break the roof braces easy ....you will need to adress some roof bracing in the future.....port and sub up will put all the pressure on your roof
Old 01-04-2016, 03:44 PM
0/11 sssss3526
Port passenger side or driver side? Meca metering tends to do well when you meter opposite side of port. At least in my experience
Old 01-04-2016, 03:50 PM
0/11 sssss1122
If your not going to meter and only sounding good and groundPounding is what you want....port towards the passenger side.....going to meter port towards drivers side........music is usually loudest at the headrest on opposite side of port
thoughts on my sa-10 box? teoulennon Enclosure Discussion & Design Construction Help 4 02-06-2013 01:14 PM
Thoughts and opinions on a box design n023b General Car Audio Discussion & Questions 27 12-21-2010 10:35 AM
what are your thoughts on... newarkbeast973 General Car Audio Discussion & Questions 9 09-01-2010 10:17 PM
thoughts and suggestions on this box? dylan9999 General Car Audio Discussion & Questions 5 04-30-2010 10:15 AM
Thoughts on box for LMS-4000 RollerDJ Enclosure Discussion & Design Construction Help 19 03-13-2009 02:51 PM
