Help with compound enclosure - Car Audio Classifieds!
Old 11-08-2009, 10:53 PM
coefamily's Avatar
0/11 ssssss336
Default Help with compound enclosure
Ok, So i have 2 Oz audio Matrix elites (12.2) one is New in Box, The other is nearly new but used in wifes car for a year.
I plan to install them both into a new project using a compound (push\pull) design.
I realize these types of enclosures use the Properties from both speakers & and in the same enclosure space to create its sound.
Will i run into problems with the speakers "marrying" well in that type of enclosure?
Will the parameters of a used speaker change enough to make that kind of a difference when running in tandem with a new one?
Old 11-09-2009, 07:56 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Moved to enclosure section.
My Car, My Ears.
Old 11-19-2009, 12:50 PM
coefamily's Avatar
0/11 ssssss336
anyone?
Old 11-19-2009, 01:05 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
You're going to put them in a compound isobaric enclosure?
Like this one?
I would recommend swapping the new one into your wife's car for a bit to break it in but if that is not possible it will not kill the sub to run them together before one is broken in.
/ CAAA Member #2 /
Old 11-19-2009, 01:14 PM
0/11 ssss31258
Originally Posted by coefamily View Post
Ok, So i have 2 Oz audio Matrix elites (12.2) one is New in Box, The other is nearly new but used in wifes car for a year.I plan to install them both into a new project using a compound (push\pull) design.
In a push pull design, the sealed volume of air between the woofers makes their individual parameters disappear.
You can not used speakers of different xmax or impedance because that would be destructive.
The other parameters are not destructive and when mated the result is essentially one moving structure with double the suspension and double the motors with half the surface area so it is much less efficient but it can get lower in a smaller enclosure.
(you can use a new sub and an old sub together if they are the same model.)
I have seen paper/pulp cone subs destroy themselves when people accidentally forget to make sure the subs are moving the same direction. {the strongest cone won}
So anyway... much like everything else compound isobaric is a method of gaining control and reducing the resonant frequency of a speaker.
That was useful back when speakers were designed to be acoustically suspended and had high "VAS" [euivalent volume of air] as well as higher "Fs". [resonant frequencies]
Today, Subwoofers have great control and much lower VAS as well as low Fs.. So isobaric is not beneficial like it was with "loose" speakers
Old 11-19-2009, 02:47 PM
coefamily's Avatar
0/11 ssssss336
THE ATTACHED PICTURE IS WHAT I HAD IN MIND
AS STOLEN FROM
Lincolntc690
Old 11-19-2009, 02:52 PM
HiloDB1's Avatar
0/11 sssss3158
Thats not a compound loaded enclosure
Old 11-19-2009, 03:18 PM
0/11 ssss31258
HiloDb1 is correct. That is just a normal sealed enclosure with one speaker mounted inverted.
Old 11-19-2009, 04:30 PM
coefamily's Avatar
0/11 ssssss336
Actually it considered a Push\pull design, But i was using the lingo used on this site for clarity purposes.
enclosure design pros n cons good read
So has anyone done this design (with good results anyway)
Old 11-19-2009, 04:38 PM
0/11 ssss31258
That's silly.
it's just a sealed enclosure with one speaker inverted. {people are making sh!t up again}
sorry man.
there is nothing to be gained by doing that. because it changes nothing. except the displacement of the one speaker.
need some help on a compound enclosure coefamily Enclosure Discussion & Design Construction Help 0 11-05-2009 02:21 PM
Enclosure for 1 Omega 15. hornedfrog1985 General Car Audio Discussion & Questions 15 09-17-2009 12:55 PM
Silver electrical compound anyone know? splvictim20 Technology & Computer 7 09-10-2009 08:11 PM
Enclosure for 2 15 XXX Silver-N-black Enclosure Discussion & Design Construction Help 10 04-28-2009 12:32 PM
Enclosure help for btl Team3d Enclosure Discussion & Design Construction Help 0 04-16-2009 08:45 PM
